Droopy the Plow Truck gets a Cummins 4BTA.
#31
Got a few more things done today.
Pump reassembled and installed, as well as the Vacume and Power Steering Pump:
You can see in this shot, I also got the connections for the aftermarket Water temp gauge, (back of the head) and Oil Pressure Gauge, (next to the fuel pump hole)
I also got the new seal in the front cover, installed and painted it it today. Ill have pics of that tomorrow.
Here is a tip: Whenever you do the front cover of a Cummins, the bolts have to go in the same spot that they came out of, So when I disassembled the front cover, I drew the front cover in a piece of cardboard, drilled holes in the appropriate spot, and stuck the bolts in the right spot. Makes it easy to get the bolts back in the right spot.
I also got the fuel pump painted and installed then started to work on the injection lines, getting them cleaned up and painted.
If I get the injectors soon I would like to fire it up on the stand before I put it in the truck.
More to come tomorrow!
#32
I have a Concern,..
Sitting at home relaxing, got me thinking bout the timing marks on the injection pump, so I did some more research.
When I took the pump off, I locked the timing tab in the motor so the crank to cam timing marks are dead on. So I removed the pump gear and took the pump out.
I know that I didn't turn the pump or the motor when I had it out, so I installed the pump gear back on the keyway. The research that I did earlier I found that if it has a keyway, the timing marks on the pump arent needed. Well I think that is wrong.
I took this pic today before I reinstalled the front cover:
As you can see the cam gear mark is there but the letters are just to the left of that mark.
Did I screw up and will I have to take it back apart and reallign the gear pump?
Any Quick input is appreciated as I have the opportunity to work on this tomorrow.
Thanks,..
Thanks,..
#33
#34
#35
#36
So then tonight, Lori is out of town and the kids were busy so I decided to head to the shop for the evening and get some more done on the motor.
I found this hole:
It looksd suspiciously like a tach sender location, Well sure enough that is what it is for. I happen to have a tach sender from my failed attempt to get the factory tach working on Big Ed, so I decided to install it and wll give it a try:
Got the starter painted and installed, anlong with the motor mounts and some other misc stuff.
Overall a productive evening.;Sweet
I found this hole:
#37
#38
Update for today:
I got the Injection lines reinstalled, minus the injectors. got the senders for the stock oil, and temp gauges. Got the turbo boost line kit, and installed it in the manifold. I got the front of the motor back together, belt, alt, tensioner, and clutch fan. Also got the new coolant lines run to the Aftercooler.
OH,...And as a reminder, ..Here are the before pics!,..
So at this point I am basically done with the motor. I just need to get the POD Injectors, installed. I should get them by Tuesday. I only have a couple of misc clamps to put on, and the fuel return line, dump some oil in it and get ready to start it up.
Thats it for now,...
#39
Update, Still waiting for the Performance Injectors so I can finish up the motor, Should be here tomorrow.
In the mean time, I started getting the patient ready for the for the heart transplant.
Cleaning Droopy for Surgery.
Rolling Droopy into the Chop Shop:
Preparing for the patient for surgery:
Drain the old vital fluid (gasoline) for a transfusion of Diesel.
Installing Pillar Pod for gauges to monitor the new heart.
Yea this whole post was pretty corny,..but it just kinda flowed out of me,...sorry,...
#41
That is what really counts!,....
So I was able to work on the truck for a while tonight.
I got rid of that awful Fuel System! I have had more fuel related problems with this truck, in Tank Pumps, Frame Pumps, Tank Switchers, everything,..So it felt good to Rip it all out!
I have a diesel sender that I will drop in and use that instead of cobbling up the gas sender. I just need change the plug for the sender from a 4 wire plug to a 2 wire plug.
Then I will to the fuel neck mod while I have it out.
Thats bout it for now,,..
#42
#45
Thanks Yes it is!
Here is a quick video of it running:
CUmmins 4bt Start Up on Engine Stand - YouTube
