Help.... Need '59 f100 cab advice
Well I did it! Bought a 1959 F100 which is about 90% complete
Great..... As a Newbie I need some help and advice... The mechanics I am OK with but the scary bodywork stuff......Hmmm
Front body panels (inner and outer) and bed and frame are fine and I knew I would have to replace the doors ....
BUT main problem is that the cab is in worse shape than I thought...Needs at least the floor replaced and braced the firewall patched.
Given my welding skills (non existent) I am wondering if I'd be sensible finding a better cab so I can get the restoration under way.
I'm sure anyone who knew welding could fix the cab no problem... it is solid everywhere except the floor at front right floor and front corners.
Anyone got a 59 F100 custom cab lying around?
on
if you can find a better cab then that is the easiest and quickest approach to take.
but unless you find a cab from a drier local, then most cabs you are going to find are going to have the same or worst rust issues. those cabs are notorious for rotting the floors at the firewall area, also the cab corners, cab supports, running boards and at the pillar supports. so finding one that is in better shape then yours might be pretty tough to find depending on where you are from.
good part is that the aftermarket is offering more and more patch panels every year for these years of Fridges. complete floor panels are available along with cab supports, etc.
in the end it is your choice which way to proceed.
rgds
Mike
rgds
Mike
The '57 - '60 cabs are the same. Helps to open your options. If you are changing the cab keep the glove box door from the original (vin plate) to put in the new cab. This should keep all your numbers matching.
Good luck on which ever direction you choose. From what I have previously priced a different cab was the cheaper choice for me.
Keli
Keli
