New truck, antifreeze leak
#31
If the core is good, I wonder if a good radiator shop can build and weld on custom aluminum tanks in place of the plastic ones. Even if the price ended up being as much as a new unit from Ford, I would pay for the peace of mind knowing that the plastic was replaced by welded aluminum.
EO2.. NMCB? Im with 14.
#32
I was with NMCB 24. Spent 5 months in the sandbox in '90-'91.
#33
2012 F-250 radiator leak
My truck is having the same issue with the radiator leaking on the driving side right off the plastic tank. I'm 3000 miles over warranty with no ESP plan (I am purchasing ESP plan in the morning). Apparently Ford needs to post a TSB (Technical Service Bulletin) on these radiators. I've had TWO dealerships tell me this problem is a very common problem!! One dealership told it was going to be $1700 & the other dealership, at first, said it would be $1500 but would call Ford to see if they could get some financial help! The dealership called back and said it would be only $900, basically cutting out the labor charge!! Ford has the parts market cornered because no aftermarket parts available yet!! Well, after reading on the radiator topic on this forum page and a few others forum pages and by the word of two different dealers that's its a common problem, I believe the radiator manufacturer need to re-evaluate their product or Ford need to change to a different radiator that can hold up!! I did call Ford Customer Service and filed basically like a product grievance. The Ford Rep said he has put the case in as replace at no charge. I guess I will see how they handle this!
#34
#35
Keep me posted, runtowin. If you'd like me to step in and help, just send me a PM with your full name, best daytime phone number, VIN, mileage, and servicing dealership. I'll check things out and see how I can assist.
Crystal
Crystal
#36
I too thought I had the dreaded radiator leak. Coolant on the steering damper and center tie rod, passenger side. Turns out after a pressure test that it's one of the hoses at the water pump. Tech at the dealer says he sees more of them leak when cold (it's been COLD here) than when warmer. Anyway, secondary cooling system, and not enough leaked out to put the level below min, guess I was lucky to see it.
#37
2012 ford f250 radiator leak
fgfgasdfasdfasdf
#39
fadfasdfdfasdfasd
#40
Hi Jacob,
I don't have the ability to make or receive calls; I suggest sending me a private message (PM) with your information. Additionally, I recommend editing your public post to remove your personal details. If you'd prefer to speak with someone directly, you can contact our Customer Relationship Center at 1-800-392-3673.
Crystal
Crystal
#41
Hi Jacob,
Crystal
Crystal
ive been trying to send you a pm and i cannot find where to send it at ive looked pretty much everywhere and cannot locate it...i just took my truck to the dealership and dropped it off this morning to get the radiator fixed on it and they told me they trucks like this come in every week to get it replaced
#42
hi crystal
just found out that i cannot send you a PM because i havent been a member for more then 10 days....is there any other solution for you to helping me out?
thank you
#44
As Hdslider mentioned, your best bet will be to contact the Customer Relationship Center for assistance. They can offer the same help that I can. Give them a call at 1-800-392-3673.
Crystal
#45
Radiator Leak
I called Ford Customer Service. They put in a service complaint and the very next morning the area service manager called me. He told me they pay for half of the replacement cost. It ended costing me $750 and the new radiator has a 2 yr warranty. I have since purchased the Extended Service Plan.
