New truck, antifreeze leak
Old 07-11-2011, 10:12 AM
glong15650's Avatar
glong15650
glong15650 is offline
2011 Super Duty, SB, 6.7, Lariat, SuperCab, FX4
Undercover hard bed cover, Ford bed mat, and mud flaps.
www.undercovercoverinfo.com
Traded a 2003 Expedition with 100k miles on it.
It was time for a new tow vehicle, I tow a 30 foot travel trailer.(7000 to 8000lbs)
The dealer offered me a deal at invoice plus all of Ford's incentives, so I couldn't
refuse.
I have about 1300 miles on it and it runs fine.
I have been noticing a wet spot under the right front of the truck,
checking today it looks like anti freeze leaking from above the air condition pump.
It makes about a 3 inch diameter wet spot, the fluid recovery bottles are still
at the correct cold coolant level.
I couldn't get my hand in that space to find where it is leaking from.
Old 07-11-2011, 10:26 AM
lakedweller's Avatar
lakedweller
lakedweller is offline
Are you sure it isn't just sweat dripping off your AC? Does it smell like antifreeze? There was another guy with the same problem on this forum. If you are unsure take it to Ford....
Old 07-11-2011, 11:01 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
You have 2 coolant reservoirs. Keep a close eye on both but likely the one on the passenger side up front is the one to watch, it services the EGR cooler which is also on the passenger side of the engine.
Old 07-11-2011, 11:23 AM
glong15650's Avatar
glong15650
I am planning a 1500 mile towing trip in a month, I will take to a Ford dealer to
have it checked.
It is antifreeze, I can see were it is dripping on the AC pump, I don't think it's a
serious leak.
Hope it can be an easy fix.
Old 07-18-2011, 11:26 AM
glong15650's Avatar
glong15650
The antifreeze was coming from the overflow tube on the secondary recovery tank.
It must have been over filled?
I guess the warmer weather must have caused more expansion of the fluid.
The dripping is drying up and the leak is gone.
Old 07-18-2011, 11:28 AM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Thanks for the update. I've been watching mine since your original posts and found no leaks or drips.
Old 02-15-2012, 03:09 PM
glong15650's Avatar
glong15650
It wasn't the overflow after all.
The leak was so small it was hard to pinpoint.
It leaked about a quart in 6000 miles.
While I was changing the oil I noticed the back of the AC pump was damp.
Had the system pressure checked and found the top hose was leaking on the
secondary cooling system.
The hose was replaced due to a damaged "O" ring.
Glenn
Old 02-16-2012, 09:48 AM
Paratrooper84's Avatar
Paratrooper84
Paratrooper84 is offline
I'm glad they found your problem!
My truck is getting pressure tested as I type this message. I noticed a wet spot under my truck as well. I crawled under the truck and could easily see orange fluide dripping off the radiator on the driver side.
I would post a picture of it but I have no idea how to do it on this forum.
I'm interested to see what the outcome of my pressure test is!
Old 02-16-2012, 10:44 AM
EpicCowlick
Here's a guide on how to post pictures:
https://www.ford-trucks.com/forums/1...he-forums.html
Old 02-16-2012, 02:56 PM
srkr's Avatar
srkr
srkr is offline
I took mine in for a radiator smell about 2 weeks ago. They fixed it...then 4 days later I had red fluid drops on my garage floor. Monday they just installed a new radiator. 36,000 miles here.
Shane
Old 02-16-2012, 04:16 PM
Paratrooper84
Well got off the phone with the Service Manager about an hour ago and they are ordering a new radiator for my truck. She has 31000 miles on it. I wasnt able to get into the details on where exactly the leak was and what possibly caused it (I was running into a meeting) but when I pick her up, either tomorrow evening or Saturday I'll get the details and post.
Epic,
Thanks for the link! When I get home tonight I'll try to upload a picture.
Old 05-10-2013, 08:36 AM
wmingari's Avatar
wmingari
wmingari is offline
Just took my 2012 F250 6.7 in to the dealer, for a very small leak on the driver side, just below the radiator. 35,500 miles and they are replacing the 1100.00 radiator. They said its a fairly common issue, and the guy that gets over 36k miles with no ESP is going to get screwed.
Bill
Old 05-10-2013, 08:00 PM
marchare011's Avatar
marchare011
marchare011 is offline
Welcome aboard.
Glad you're getting taken care of. Hopefully the new radiator will outlast the old one.
Old 05-10-2013, 08:27 PM
wmingari's Avatar
wmingari
wmingari is offline
Originally Posted by marchare011
Welcome aboard.
Thanks for the welcome... I hope it does also.
Old 12-25-2013, 01:14 PM
apd966's Avatar
apd966
apd966 is offline
Same issue w/2012 f250 6.7
Bill
Just noticed several days ago red fluid leak on drivers side near radiator pitcock. Taking it tomorrow. Sounds bad.
Quick Reply: New truck, antifreeze leak
