New Brake Rotor Turned Blue (Heat) in 8-miles, Keep Using or Replace?
So I changed all four rotors (Motorcraft) & Pads (Wagner ThermoQuiet)and flushed the brake fluid.
Took a test drive afterwards (8-miles total). Brakes worked as expected, but when I returned I "smelled something". I immediately went around & started checkin each wheel ... all were good except the right rear.
Apparently I have a sticky caliper or a collapsed brake line (haven't quite narrowed it 100% but I'm pinning it on the caliper) ... the new pad must of dragged on the new rotor for the entire 8-miles. The heat was enough to turn the rotor blue.
I'm no expert on this, so I'm asking ... should I correct the problem & continue using the pad & rotor that was heated? Or, is it recommeded to replace everything if the rotor turned blue??
Did you grease the slid pins? That would cause this if they are stuck. Here is how to do this if you don't already know. Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
on
1 Post
You are going to have a hard time finding someone who will turn the rear rotor with an on-car lathe, so if you were going to have someone bench turn it I would not bother. You won't end up getting the rotor back within it's spec of under 0.001" installed runout.
As long as there are no hot spots which sometimes can be seen as shiny areas, I would reuse the rotor as is. It heated up and cooled uniformly, probably getting up to about 600-800°F depending on the "blue". Just look for spotting as that will be the key if it can be reused.
I would be more worried about the brake pad, not only being scorched, but the long term integrity as the underlayer or bonding to the steelback could be compromised. Pads tend to shuck at the most inopportune times.
I agree with redford on this.
Iron will surface crack when there seveverly over heated. If it was very bad you should be able to see the cracks fairly easy. On the other hand if the rotor is not cracked or warped I'd probably reuse it because I'm poor. Bonded pads that have been super heated would make me nervous though
I picked up a re-man caliper over lunch and will install it this afternoon. I've pinned it on the caliper 'cause only one of the two pistons would extend when the pedal was pressed. I would have to hold that piston & hit the pedal again to get the other piston to extend ... and after that it would not compress w/o a bit more force than the other. I saw no other issues with the set up whatsoever ... so if it's "not" the caliper, then it has to a collapsed line (I did release the bleeder valve when the caliper was pressing the pads against the rotor and it dot not release).
Other than the blue discoloration on the rotor, I saw nothing else. The pads also did not appear to be any different than when I installed them 8-miles earlier. I'll reinstall everything and feel for a pulsation .. if there, then I'll replace both the rotor & pad.
Oh, the rear pads had about 3/16 of material left before changing ... I only replaced the rears because I did the fronts. I wanted to do all four at the same time ... the rears probably did'nt "really" need it.
