Rotor Size/Please Help
Does anyone know what size the front brake rotors are on a 04 6.0psd? I have looked at 2 diff parts stores and they each have two diff. sizes for the front rotors. One store is 13" and 14.5" and the other is 13.03" and 14.53". I don't know what size i need for the front. I have called 3 diff. ford dealerships and they all say there is only one size that they show. They all 3 also said that they did not show a size like the parts stores are giving me. Thank you for any help.
Sounds like i might just have to pull the wheel off and measure the rotor to figure out if i have a 13in or 14.5in rotors. I will be measuring the surface that the pad would brake on, not the the back of the rotor that mounts to the hub? I know that is probably a dumb question but i just want to make sure.
Funny you should ask. Thought I'd just slap a wrench on it and tell ya but I guess it can't be that easy. I have two wrench sets and neither one has a 16mm! 15 is too small 17 is too big. A 5/8 fits pretty good but looking at the bolt it has metric markings. Put a mic on the bolt and came up with .6246in. That doesn't work out to be anything so I must be a little off. 16mm=.6299, 15.5mm=.6102, 5/8=.6250 so it looks like 5/8 is the winner!
MY............Loc........................Rotor.... .....................Caliper...................... ........Friction................
99-04.......Front........K-H / TRW 331 x 38 mm....Akebono Twin 54mm....Abex / Federal-Mogul 1222-1A EE
https://www.fleet.ford.com/truckbbas...essd_04abb.pdf
there is no nut for the rotors
take it off at the 2 bolts that mount the caliper and set the whole caliper assembly on the leaf spring or tie it up and then PRAY that the rotors are not seized on
I also spread antiseize on rotors where it contacts the unit bearing
Benny - I believe these are correct:
Brakes, disc, front brake caliper pin bolts (2)......................42 ft-lb
Brakes, disc, rear brake caliper pin bolts (2)......................27 ft-lb
Brakes, front disc brake caliper anchor plate bolts (2)...........166 ft-lb
Brakes, rear disc brake caliper anchor plate bolts (2)......128 ft-lb
Brakes, Caliper Bleeder Screw................................13-18 ft-lb
