Mine is different because since I replaced the carb I have to pour a little gas down it for the first start of the day, and it idles at about 3000 RPMs and I have NO idea how to fix that.
check the carb gasket wit some carb spray around the base of the carb....
different I guess because its a 74 F250 Crew not many of them made. An that it has 30K original miles an is totally stock wth the Ford Blue paint still on the I beam & engine & stuff.
A friend of mine had a great idea because he had the same problem and was never able to solve it. If you rig a primer pump inline to the carb all you would have to do is reach in there filter on and squeeze that pump a couple times. Hope it helps.
You know, it sounds like you have a vacuum leak. Did you replace the carb mounting gasket when you switched out carbs?
1979 F350 SuperCab 4x4, what makes this truck different.......here we go. It started out to be just a simple re paint then i got bit by the bug and decided to do a complete frame off rebuild, Dana 60's gone thru, C-6 built for the 4 bolt main SCJ 429 all aluminum top end, Hydro Boost brakes, power seats, power windows, power locks, factory cruise and A/C and tilt, custom stereo, all NEW factory Ford trim found in attic purchased 25 yrs ago, this list goes on and on......Chip Foose signed glovebox too!
What makes mine different? Hmmm well I bought my 1979 F250 Ranger 4wd off a friend for $200... fixed er up... put in a, far as I know, stock 351m straight piped (and sounds AWESOME!!!), the homemade flatbed.....
the bullet hole in the hood ()
the 73-77 front bumper with a 78-79 push bar,
the repainted headliner (used krylon farm implement spray paint)
