Max tire height for a stock 1987 f250?
Does anyone have an idea of what the largest/tallest tire I could fit on a late 80s f250 (2wd, stock) without rubbing? From what I've gathered 33inches seems to be the number, but I've not found anything specifically for the late 80s to mid 90s generation.
Received 3,103 Likes
on
Did you have to replace the wheels themselves? Because as far as I can find, the wheels are 16.0 stock. Or would the .5 not be an issue?
Definitely DO NOT try to mount a 16.5 tire on a 16 inch rim. Not safe, wont work.
Also, the gears are 4.11 ratios, so I should be looking at 32's for peak performance, correct?
edit: Looking at this site (http://4lo.com/calc/geartable.htm) it seems like 32" would be cloestest to factory, but then it goes to list 34" as having the better gas mileage? Would that account for the fact I'd have to raise the truck to get 34s under there?
Any suggestions for tires? I'm going for an even balance of looks, performance, and driving pleasure. The truck ain't gonna be doing much true off roading, but it will be doing a fair bit of driving on dirt and gravel roads, some of which barely qualify as roads, and some fairly flat farmland (probably about 35%-65% "barely counts as road" to city/highway/expressway driving). Will be occasionally, as in every few months, be called upon to pull a one or two horse trailer.
roughridn_sob
27
01-10-2015 08:20 PM
ryanguy76
1999 to 2016 Super Duty
13
07-16-2011 10:49 PM
lynch3763
02-04-2011 10:55 AM
superdutymj
32
05-06-2008 03:45 PM
jeep8589
1978 - 1996 Big Bronco
03-03-2004 07:27 PM
