smog delete pulley
Old 07-08-2011, 12:20 PM
mojo79's Avatar
mojo79
mojo79 is offline
My truck is exempt from emssion testing, but all the emissions equipment must be installed. It doesn't have to be working, but must be in place. NC law.
This is why I prefer to use shorter belt rather than eliminator pulley.
I was hoping someone could tell me which belt size would accomadate this.
Thanks
Old 07-08-2011, 12:24 PM
mojo79's Avatar
mojo79
mojo79 is offline
Oh, Ok... I did not use the belt re-routing diagram. I thought with the shorter belt I would be able to use OE belt routing. let me look at that agian... thanks White Max.
Old 07-08-2011, 12:36 PM
mojo79's Avatar
mojo79
mojo79 is offline
Ok, with the new belt route (not using idler pulley) I will be required to remove smog pump pulley for clearance... which I'm not opposed to if this is my only option.
Is there a shorter belt length that I could use with original OE belt route? I'm thinking I only need another 2 - 3 inches shorter.
Thanks
Old 07-08-2011, 12:43 PM
White Max's Avatar
White Max
White Max is offline
Thanks
Nope. Been there, tried that. With that FEAD arrangement, just skipping the smog pump doesn't work. The tensioner isn't able to tension the belt, so it flies off as soon as you put any rpm or load to it (turning the steering wheel, for instance).
Old 07-08-2011, 02:57 PM
CS45's Avatar
CS45
CS45 is offline
I've tried this also. I ended up getting the eliminator pulley and used my stock belt. The $50 buck cost gives me great piece of mind. Truck runs flawlessly.
CS45
74F100LGM
19
07-18-2022 11:04 AM
mramc1
64
06-23-2021 02:34 PM
Fordman2822
17
03-31-2018 02:07 AM
BigBear1
06-15-2016 01:17 PM
dferg250
12-24-2011 05:23 AM
Quick Reply: smog delete pulley
