06 F 150 sof 4x4 wont engauge
P1867 code is transfer case contact plate circuit general failure. P1891 code is transfer case contact plate ground return open circuit. Most likely needs a transfer case shift motor. Very common on these trucks. Had to replace on my 06 as well. It was done under warranty. I hope this helps.
A lot of times you can get it to engage by smacking it with a hammer. If it does engage, it's definately the shift motor. That's how the dealership tech diagnosed mine. I make it a point to engage 4wd once every month or two just to make sure it works. It's especially important for me since I don't drive the truck a lot. I drive an old beater 01 Sable LS every day because it gets 9-10 mpg better than the truck. At 300 miles a week I save $20 a week driving the Sable which more than covers the plates and insurance on it.
jmorris47
15
04-22-2008 05:01 AM
