99 to 99.5 upgrade
Old 07-05-2011, 02:38 PM
strokensmoke1's Avatar
strokensmoke1
strokensmoke1 is offline
99 to 99.5 upgrade
Hey im new on FTE so im still trying to figure things out! but I have a early 99 and i wanted to know what all i need to upgrade to bring my truck up the 99.5 specs. and a rough price of things would be awesome! thanks!
Old 07-05-2011, 02:44 PM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
Here check this out and if you have any q's give Clay a call at riffraff diesel performance.
Riffraff Diesel: Riffraff Early 99 7.3L Conversion Kit
Ho!! and by the way welcome to FTE.
Old 07-05-2011, 03:02 PM
Brother Les's Avatar
Brother Les
Brother Les is online now
Welcome to Ford Truck Enthusiasts.
Old 07-05-2011, 03:54 PM
ltl_jrw's Avatar
ltl_jrw
ltl_jrw is offline
You will need new turbo, up pipes, babys butt, pedestal, spider, boots, intake that bolts to heads, HPOP, intake boot from air cleaner to turbo and really injectors, about all I can think of. Cost (turbo = $650) (up pipes = $?) (injectors = $1050) (HPOP = $450) (Boots = $150) and you get the picture.
Welcome to FTE
Old 07-05-2011, 04:06 PM
leekingen's Avatar
leekingen
leekingen is offline
i just did this upgrade, had to get all the parts {bc} befor clay.no new hpop or injectors.truck runes grate with alot more power
Old 07-05-2011, 04:46 PM
429 f-100's Avatar
429 f-100
429 f-100 is offline
x 2 what richard showed you.i to have a early 99 and have been debating upgrade or not and now clay has me all messed up with his new kit i really want it !! injectors i would hold off and get everything else done plus exhaust and gauges , than go to single shots and a tuner thats what i want but tough to swallow this all this at once!
Old 07-05-2011, 04:51 PM
429 f-100's Avatar
429 f-100
lee what did you change ? so you feel a big differance? i am debating this now as my turbo has 267000 mi my up pipes are seeping . man the up pipe kit for the early one is 7 bills and all the exhausts are for the later model.almost a no brainier with clays new kit with the 38r just tight now on money,
Old 07-05-2011, 05:06 PM
leekingen's Avatar
leekingen
well first off when you go with the upgrade u get a differint pedestal and torbo and with it setsup about a inch higer so you dont need a early uppipes. i think just going with a stock 2001 turbo, rebilt realy was the differance. i did fined all the parts off e-bay except uppips that i got at a ford dealer. i would have gon with clays kit but then agen money is the main thing with me
Old 07-05-2011, 05:17 PM
429 f-100's Avatar
429 f-100
lee so you went with the factory not bellowed up pipes. so just having the later turbo and bigger intakes you can feel a big difference?
Old 07-05-2011, 05:22 PM
leekingen's Avatar
leekingen
yea and i did gut my exhaust valve and 4 in turbo back exhaust.you also should go with 6637 intake
Old 07-05-2011, 05:23 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Welcome fellow Floridian.
Old 07-05-2011, 05:34 PM
429 f-100's Avatar
429 f-100
thanks lee i did the 6637 already but on the fence about keeping the old and maintaining or switching to the later set up seems like the new kit hes got has sorta made the decision harder because its probably cheaper and better to go ahead and switch . just after i decided to stay stock and maintain now seems like a bad choice. have you seen his new kit just appeared last week a 38r turbo/ a blank late model pedestal / intakes on head / inserts / afe spiders / bellowed up pipes / boots / high flow turbo output / and all clamps and hardware . pretty sweet complete kit add injectors and a tuner and hold on !
Old 07-05-2011, 05:40 PM
leekingen's Avatar
leekingen
yes i did see that and its a sweet setup. not looking to race just to keep the truck running longer.pm sent
Old 07-05-2011, 05:49 PM
429 f-100's Avatar
429 f-100
yea i wasnt trying to race either ive managed to stay stock and not touch it for 13 years and 267000 miles now, but now after reading here for 6 months ive been bitten buy the mod bug . i thought my truck was pretty powerful but now i know better . not trying to drag race it but while doing simple maintenance stuff there is better ways . i didn't know how different the early 99 was till i came here.still debating on switching over to the newer setup.
Old 07-05-2011, 05:56 PM
leekingen's Avatar
leekingen
yes pms has got me to do alot of things.not just upgrades but good maintenance . thanks to every one at fte for that.
Quick Reply: 99 to 99.5 upgrade
