What year is this truck?
1957/80 has a 11 digit VIN / 1981/86 has a 17 digit VIN
The door emblems on this truck with the yellow reflectors were introduced in 1968, used thru 1986 on C Series.
I am from Texas but that truck is in Arkansas. I have no idea right now what the city would want for it.
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
C99169 = 1968, assembled March 1968.
Assuming the following codes were listed in sequence from the Warranty Plate. Some of the codes were omitted.
63 should be 163 = wheelbase in inches.
COLOR: Omitted.
MODEL: C701 = C700 Tilt Cab, 17,000 lbs. Gross Vehicle Weight Rating.
BODY code composed of 3 digits, not 2 (91).
TRANS: M = Clark model 285V 5 Speed Direct.
AXLE: Omitted.
MAX GVW LBS: Omitted.
CERT NET HP: Omitted.
RPM: Omitted.
DSO: 52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from.
C70 = C700 Tilt Cab.
Assuming the following codes were taken in sequence from the Warranty Plate.
91 is the body code, but the 1st digit is missing.
