1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
1989 f250 fuel issue
Old 09-06-2016, 10:42 PM
Blueriver16's Avatar
Blueriver16
Blueriver16 is offline
Question 1989 f250 fuel issue
My 89 f250 is having a fuel issue. I can't use my front tank for fuel so when I am running on the rear tank it also pumps fuel to the front tank when in use. I think it is the tank switching valve that might be bad. I had to much fuel in the front so while on the rear tank it pumped fuel to the front and caused it to overflow. If this is the problem where can I find this part? Any thoughts? Thanks
Old 09-07-2016, 07:31 AM
1tonner's Avatar
1tonner
1tonner is offline
Post in correct forum for better help.
stephen.andersen
05-15-2018 02:20 PM
Passin Thru
01-26-2010 01:02 PM
jeffsk7
03-25-2009 12:48 AM
Quick Reply: 1989 f250 fuel issue
