Another 2WD levelling/lift kit ques.
Just picked up my X today. 6.8L, limited, 2WD. I'm more excited about it than the old airstream trailer I bought to go with it. Anyway I would like to lift it 2 inches and give it a 4WD stance. I've found 6 inch kits, but I'm just looking for some extention coils and blocks for the back. Thx for any info/links.
A quick search would have given you what ya wanted!
Here's my thread on the spacers. https://www.ford-trucks.com/forums/9...ml#post8492932
Pay attention to post number 21. I have links to two threads in that post that are important if you plan on using spacers on your rig.
Also, there are plenty of pictures for you between all three threads.
Stewart
Stewart
Stewart_H -
Thanks for the above link. I went for the billet spacers for the front along with all new bushings, ball joints and tie rods. I'm in the process of installing everything now......this forum is a great source of info.
I think my rear springs have sagged and I may need to add a taller block above the rear axle to get things level when I finish the front. I see folks using F350 blocks to raise their 4x4's (ford part no. F81Z5598da). Does anyone know if these blocks will work on a 4x2? If not, any info on compatible blocks? I'm looking for just a 2 inch increase in lift. Thx!
Unless your suspension is worn or not performing up to your specs, and replacing the coils and leafs will make it better, then it's just money down the drain.
For me, I plan on replacing the rear leafs on my F250 mainly because I just want a set of fresh springs back there. I figure the previous owner must have towed a lot with a gooseneck, because whenever I hook up my dump trailer, the rear end sags more than I like, and whenever I hook up our travel-trailer, it really makes the rear-end squat.
Plus, I like to drag race my truck in Division 2, NHRDA and a better suspension will help with my launches.
So will a set of traction bars, slicks, a new rear diff, blah, blah, blah...the list goes on for this money pit!
Stewart
Stewart
