my exhaust fell off today from cat back. Flowmaster super 44 install COMPLETE
ok well driving down the road it all or a sudden sounded meaner then normal.... atually i was playing with a dakota and stepped on it and it sounded alot more agressive al of a sudden then the ting ting and metal on metal sound started as my muffler was rubbing the drive shaft....
well i wanted to do something with the exhaust and i guess this is the time to do it.
i dont have an emissions laws here or annual inspections so im not worried about that part.
i was thinkling of just adding a 2' piece of pipe (just to bring it past the cab) and a turn down. then i got thinking can i remove the rear cat without causing any issues? if so im just going to cut it off and make the pipe a little longer with the same turndown under the box.
without a muffler and tilpipe i like the sound but would like a little louder. by removing the rear cat i can acomplish that right? will there be any issues with the o2 sensors? i beloeve the sensor is before the rear cat am i correct?
any suggestions?
thanks, midnite
any suggestions?
thanks, midnite
EDIT: i re read what you wrote EDGETHIS, i think im going to run thestraighty pipe to under the box for now and might go sde infront of the wheel or put the tailpipe on afterwards
Why use little 2 inch pipe? I would use at the minimum at least 2.25 or 2.5. I would suggest running 3 inch single on your 351. The size of the exhaust pipe between the 2 cats is an odd size and 3 inch pipe fits right over it. I agree about not liking turn downs though. I would run tail pipes out the back or something. Magnaflow makes a nice single 3 inch tail pipe for our trucks. I think Dynomax or someone similar also makes one. Several people on this site have used them.
I had turndowns before, but you need the right muffler to sound good, i had a super turbo dumped before the axel it was freakin deep sounding but rattled the hole inside of the cab, also had a Cherry Bomb extreme dumped not as bad and sounded great outside.
well made some progress. have to take it to work tomorrow to weld it together and make some hangers
with stock cat and no muffler/ tailpipe
YouTube - ‪1995 f150 cat only‬‏
cat, muffler and tailpipe all removed. open headder
YouTube - ‪1995 f150 cat muffler and tailpipe removed‬‏
super 44 mocked up with no cat
YouTube - ‪1995 f150 flowmaster super 44 no cat mocked up‬‏
finally finished the exhaust.
love the sound from outside and parked. but thought it would be louder when driving but as it exits out the passenger side the sound doesnt travel to the driver seat that well. no drone on the highway either.
painted it all black with headder paint.
YouTube - ‪1995 f150 5.8‬‏
Kapusta
15
12-06-2015 01:39 PM
Last_Level_II
1983 - 2012 Ranger & B-Series
09-29-2015 05:35 PM
