Of boost and mileage.......Luring DP Tuner in to comment....
This question I was attempting to "lure" someone from DP Tuner in to help answer, but all feel welcome.
OK, There have been several discussions on the 6.4 L diesel, of how mileage is so rough. I seem to remember someone working on a tune that was supposed to be a 7.3 extreme mileage tune, and ran lower boost.
My point on the 6.4 was, once the EGR is disabled, the boost the truck makes is too high. My thoughts were leaning towards venting exhaust past the turbocharger to achieve a lower boost down the highway, resulting in higher MPG's.
Am I wrong in thinking that too much boost can hurt mileage?
Am I right in thinking that pushing more air than the truck can burn is a waste?
I know this isn't 7.3 specific, but really it isn't 6.4 specific either, it's just "turbocharger" specific.
Thanks.
Thanks.
Could it be that the excessive boost is creating more backpressure then necessary? The EGR system is probably acting in a way that similar to the waste gate, but dumps to the intake instead of the exhaust.
I'd think that more air then necessary would keep the EGT's down, but thats just my thinking.
Thanks.
Thanks.
Boost levels are engine/turbocharger specific. Variable vanes, compounds, turbo size... all these different configurations will completely and totally change the spool up rate, and the amount of boost you see say at highway speed. Furthermore, the engines themselves, regarding volumetric efficiency, fueling, timing, displacement, emissions controls, etc... all play a role.
Intentionally bleeding off boost simply so your gauge reads lower is not going to help. Instead it's going to hurt. The amount of boost you see is simply a by-product of the combination of parts, engine efficiencies, how much that engine is fueling, how much power it's needing to make in order to maintain that speed, and the resulting exhaust gasses that spool the turbo. More air is never a waste.
People simply use boost as a general reference of fuel economy. It's a "poor man's" lie-o-meter. That's all it is. Nothing more. It is not always a true indicator of fuel mileage, just like the overhead display. Heck, you could run 3 psi of boost, but have 1000 degrees EGT's.... and your fuel mileage will suck.
You're thinking about this all backwards. You don't bleed out boost in an attempt to lower boost and raise fuel mileage. In fact, the exact opposite would be achieved if you even tried that.
But if you're cruising down the highway, using maybe 45 HP, a turbocharger is causing back pressure when the engine is in no need of positive manifold pressure.
Well I know Jody from DP tuner is on here once in a while, and also remember they were working on a tune w while ago that was running very low boost on the 7.3, like almost 0.
I don't know the exact specifics of it, or if they ever managed to finish the tune for mainstream use, but I though they might have some input as to my current question.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
When my 6.4 dies, I plan to buy a brand new truck, because I heard they're getting smaller, so I want to buy a brand new one the year before the downsize, so I can laugh at everyone will small superduty's.
