AC Compressor Mounting Woes, belts, etc. *pics*
A dealer is going to do whatever is necessary to get the job done the fastest and get the customer's money.
Even though Ford had kits for adding AC to various vehicles & engines, that doesn't mean a dealer always used all the parts in those kits or didn't mix-n-match components as they found necessary to do.
It looks to me like the AC compressor belt is intended to fit onto the outermost pulley. If you have all of the basic parts, and you're sure you've got the correct compressor, then perhaps some ingenuity & engineering on your part is in order to adapt things so that they work?
So, still working on putting AC in my new project. Found a mount at the junkyard for the style AC compressor designated for this truck. Bought a new compressor, and nothing seems to align just right. The pulleys just don't match up!
Take a look, let me know what you think,
In the middle picture, you can see that the alternator has a double-wide pulley; the inner is for the the connection to the water pump (or crankshaft or wherever it connects to the engine) and the outer is supposed to be driving the smog pump.
You can see the correct configuration in those diagrams I've been posting.
It looks like you have the smog pump connected to the AC compressor's pulley.
Notice the three spacers/shims that go between the PS pump and bracket? There's what seems to be missing. Those should move the pump back far enough to use the center groove on the balancer/pully, which will then free up the front one for the A/C belt.......
That looks wrong to me.... the smog pump (located above the alternator) is supposed to connect to the alternator below it.
Iin the middle picture, you can see that the alternator has a double-wide pulley; the inner is for the the connection to the water pump (or crankshaft or wherever it connects to the engine) and the outer is supposed to be driving the smog pump.
So I have been doing my research on the original compressor on this dealer installed system. Looks like it originally had a Sanden 709 compressor found in 1989 Saab's
The stuff mounts up just right!
Just search york, sanden conversion: https://www.ford-trucks.com/forums/tags/sanden.html
#28
I want to say that Ryan has the big square "york" compressor on his rig. The round body FS6 is more common with the factory installed setups. However, the Sanden compressor is more common on dealer and aftermarket setups. It gets kind of toasty here in AZ without air. It's 113* right now!
#30
