The Mark VIII fan is the only way to go. I have mild 460 in this 90 plus weather I have yet to get over 190 degrees. Takes the worry out of sitting at lights or traffic.
oh, so the back up fan from my 95 town car should be just the ticket....
my 78 f150 /302 came with what i think is a taurus fan .... its mounted with strapping , and the wiring is mainlined directly into the ignition switch......needs to be entirely rethunk
Thanks for all the info.... Ak..... Do you know the approx dimensions of those brackets you made? What about wiring? Is this something I can junkyard too? What year mark VIIIs?
Mid 90's Taurus's and Sables. You do have to make sure you get the fan from a car with a 3.8 engine. I have one from a Sable in my 77 with a 302.
As far as the wiring from the JY I'd say you can get some, but you need around an 80 amp continuous duty solenoid or breaker to run the high setting (which it seems like no one who does this conversion needs the high setting). I did get my regular relay's from a Taurus SHO and the sable, though.
