RPM up & down on idle
Is this an eradic idle up and down rapidly? And what is the weather like? When cold typically under 30°F. my truck will idle up to 900-1000rpm but that is in the programming the pick commands the high idle when needed. If it is really cold it will idle up and if let run long enough and the temp comes up it will settle back to 600.
Still Have the EGR Valve? if you have a Gauge like scan Gauge monitor EGR DC also the Turbo VGT, map, EBP,Baro, If your getting pleanty of boost. need to see what EGR and Turbo are doing. then we can head to ICP , ICPv, IPR. may need to start your Own thread seeing that this one is a few years old and mostly ICP you will get better results too.
rpm
No it doesn't do it all the time and only goes up and down a little but some times it surges and I have to press on the brakes harder. There's a vibration sound coming from somewhere under the hood. Idk if it has something to do with the sct tuner that was just put on other coincidence
Josh.indorf
13
02-23-2020 11:37 PM
408 Torquer
02-14-2016 01:03 PM
ForsytheM13
09-12-2010 04:07 PM
