zf 5speed transmission swap
Hey can i swap the zf transmission out of my 95 f350 with an 89 zf transmission. I'm wondering if the transmissions will have the same dimensions and what not and if it's as easy as dropping one and bolting the other up. I'm assuming that the 89 would have a torque rating of 420f/lbs and the 95 would have 470f/lbs. My 3rd gear syncro has worn out and i'd rather not have it rebuilt when i can get the 89 for $200. Any input would be appreciated. Thanks
So for a 4x4 truck, get a 4x4 trans or a F-450 ZF.
Also to clarify, there are 3 bellhousing patterns, small block, big block and diesel. The big block and diesel are close, but not compatible. Some people have modified one to fit the other, but it only goes one way, requires drilling, and I don't remember which, but its not a direct swap.
Year to year changes are not your friend. Checking NAPA, (only because it's easy) I find a "clutch release bearing" number N4119 for a 1995 F350 with 5 speed MT, and N4061 for a 1989 F250 with same trans.
What's the difference? They look different in the picture--one longer than the other. But who knows if that's the right picture?
So, you need to look at the parts you take out and put it together with an eye for proper dimensions on those parts. It may be as simple as using all the '89 clutch parts. Or you might have to mix and match, with a '95 pressure plate but an '89 disc.
The master cylinder piston diameter changed sometime around '93. Newer slave cylinders will not work with older master cylinders and vice versa. I think Ford may have also changed the bolt pattern for mounting the slave cylinder to the firewall around the same time, preventing swapping the older master cylinder. I would put in a new slave cylinder regardless, while the transmission is out and the slave is easy to get to. I do not know if Ford changed the bolt pattern where the slave gets bolted to the transmission - someone would have to double check on that. The clutch itself probably changed very little between 89 and 95.
[quote=tecgod13;10515839]Slight correction, F-superduty or F-450 ZF are 4x4 transmissions in a 4x2 truck. But instead of a transfer case, they have the driveline parking brake.
So wouild a t-case fit where the brake assembly is without any other work?
Don't mean to Hijack the thread but got a guy with one of the brake equipped ZFs waiting for my reply to buy or not, I want to use it in a 4 wheel drive. Thanks to you knowledgeable Ford guys in advance. Been a Ford guy all my life but never involved with heavy rigs.
