79 f250 super cab 4x4
on
Really nice truck!
And you're sure tearing into it real quick too!
I almost had a deal like that... exactly same truck too, but up here in the rust belt and completely factory stock.
Not a single thing was changed, F250, factory topper, factory everything, and almost all options as well... but the old lady wouldn't get rid of it cause it was her late husbands from when he passed 10 years back.
Thanks. I was hoping you had a bought kit. I like the looks of the crossover and I'm sure it drives better than the push/pull. I'm in the middle of the D60 swap and it looks like I'm going to need a drop pitman arm and another drang link possibly. So I'm trying to decide if I should just go the crossover route.
thanks. it was actually in Yreka but the guy met me in sacramento.
About your 6" Lift and D60 up front. My pitman arm hits the front drivers side spring clip when I make a hard left turn. Did you experience a similar issue and what was the fix?
im assuming you have the push/ pull steering still? mine never hit when it did i had a skyjacker drop draglink though.. If you havent done crossover steering you should it makes a big difference.
I noticed the other night while test fitting I may have the same issue if I decide to stay with the push/pull
i got the auto trans pulled out and im now running into a few slight it. Out of the three clutch pedal assemblys i have none of them will work with my brake booster. the brake booster i have now has a straight rod coming out which connects to the pedal itself. the pedals i have are used with a different booster that uses the linkage on the firewall. im thinking the pedals i need are 79 specific because i have them in my other 79 also. im either going to find a set of pedals or change the booster.
also the flywheel i had resurfaced and installed has 3/8 bolt holes for the clutch. well the clutch i have uses 5/16 bolts as the 3/8 wont fit in the holes. i dont want to drill the clutch as i dont know if it will affect alignment or not. i do have another flywheel with the 5/16 bolt holes i can use but thats another $40 bucks im going to have to spend to get it resurfaced.
on a side note the best thing i did was buy a hb trans jack. i welded up an old trans mount so it would saty solid and drilled for holes into the jack base and bolted it up. i pulled the trans out in a few minutes by myself with out the fear of it falling off.
the trans is in i just need to i just need to do some adjustments with the linkage now. im having the front drive shaft shortened and i should have my new rear drive shaft by next week hopefully. i pulled out the rear 60 and i should have the 14 bolt in by tomorrow.
<a href="http://s32.photobucket.com/albums/d49/boggin79ford/79%20f250%20supercab/?action=view&current=DSC00605.jpg" target="_blank"><img src="http://i32.photobucket.com/albums/d49/boggin79ford/79%20f250%20supercab/DSC00605.jpg" border="0" alt="Photobucket"></a>
#29
Hey, really like the truck. Got some questions for ya that I can't find answers to. I just recently got a 78 Scab 4x4 and want to lift it. I was thinking 4", but really like yours at 6". Did you buy a kit to do it, and if so where? Since they have the front leafs, I'm having trouble finding any info about it. Mine is just an f150 with dana 44 front / 9" rear but I'm working on getting a 250 parts truck and swapping it's 8bolt dana 44 / 60 onto mine. Can you point me in the right direction for more info?
#30
