89 F350 Death Wobble
My truck has been used primarily a a plow truck on the farm for a few years, butI put it back on the road to do a few jobs, seemed fine, but now, if I hit a bump just right, the entire front end wobbles like crazy, like on a cartoon, need to come to a complete stop for it to go away. And I mean it shakes violently. The front end has a few loose ends, but they don't seem looses enough to be this bad, it has a stabilizer, lord knows if it's any good. Any ideas?
I've been dealing with the exact same issue, except I completely rebuilt the axle before swapping it in. I'd start with replacing the trac bar bushings and then the front spring and shackle bushings (I'll be doing mine tonight!). If that doesn't fix it, you may need to rebuild you kingpins.
Ya, but I've had ends this loose on cars and trucks before and never got a wobble like this.
By track bar you mean the large stationary one, I call it center link, man what does that thing cost, actually that has the most play, but I can't beleive it would transfer that much wobble to the wheel.
No, your looking at the center/drag link. The trac bar is behind the axle and goes from the frame cross member down to the axle just under the passenger side spring pearch.
If you want to try other things, here's a list of approximate prices:
Front spring and shackle bushings - $55 (Autozone)
All steering linkage - $500 for Moog, $200 for MasterPro (O'Reillys)
Kingpin rebuilding kit - $50 each (east coast gear, bronco graveyard, etc.)
There's a post somewhere on this site that talks about putting flat washers under the kingpin cap to increase the spring preload and supposedly eliminate the death wobble. I haven't tried this yet so I can't vouch for it. I'll see if I can find a link for you.
A set of Moog trac bar bushings only cost $21 at O'Reillys.
Muddy Creek
15
11-13-2015 03:35 PM
F-250 restorer
11-01-2015 05:20 PM
