3rd gear
Old Jun 26, 2011 | 12:44 PM
jimmybobby 116's Avatar
jimmybobby 116
3rd gear
01 f350 When it tries to shift into 3rd gear feels like i threw an anchor out. 1st 2nd and reverse are all fine. Pulled pan and front valve body, no clogged ports or valves that I can tell.
Old Jun 26, 2011 | 01:45 PM
snakedoc's Avatar
snakedoc
in 2001 there is a diode in there that can go bad
Old Jun 26, 2011 | 04:50 PM
jimmybobby 116
Closest scan tool to me is about 50 miles that I know of. Does this diode cause the issue I described, seems to be lots of problems out of these trannys.Is the diode something that is replaceable by a mechanically inclined gearhead or is it inside the housing? thank you
Old Jun 27, 2011 | 05:28 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The "diode" is a one way clutch inside the transmission. Replacing it involves a complete trans rebuild, including changing some hard parts. It's not a simple job.
Old Jun 27, 2011 | 06:12 PM
jimmybobby 116
yeehaaaaa just what i wanted to hear lol thanks for info
