Im working on a 65 F600 with a 330 md, I’m adding a power steering pump so I need the extra pulley that bolts to the main crank pulley. I’m hoping someone can give me a part number or if someone has one available. I have one for a 391 but is slightly different. Thanks
There was never a single sheave outer accessory pulley available for FT engines, only double and triple sheave pulleys.
And the 5 groove add on pulley, the 391 powered LT800 at the local mill uses 7 belts, 2 for the water pump and alternator, 2 for the power steering pump, one for the air compressor and two more for the high mount fan.
Hi, I was wondering if you could decode my 1999 Ford F800? The VIN is 3FENF80ZXXMA21745. To be specific, I'm trying to figure out which Master Cylinder I need, looks like there's a couple choices in the bore sizes and it appears to depend on the caliper size on the front axle.
VIN does not contain any brake info, post a pic of the Certification Label or type all the codes.
