OLD DECODES
#946
And the search begins. Any chance of getting some part numbers NumberDummy on the drivers door vent window glass and door locks?
if the locks come as set including the ignition its fine. the ignition was changed and the previous owner doesn't have the keys to the doors.
Anything you can find out is greatly appreciated, thanks in advance. You Rock.
1970/89 L/LN/LNT/LT/LTL/LTS500/900.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
LONG LEWIS STERLING in Bessemer AL has 2 = 800-476-3716.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 168 = 800-476-9653.
D0HZ-8021412-A Clear & D0HZ-8021412-B Tinted .. Vent Window Glass (NAGS: 2599T) / Obsolete
GREEN SALES CO. in Cincinnati OH has 1 = D0HZ-8021412-A clear glass = 800-543-4959.
NOS PARTS SOURCE has 1 = D0HZ-8021412-B tinted glass.
Check with local auto glass shops if this is still available. Give them the NAGS (National Auto Glass Society) number, specify clear or tinted.
#951
the part search continues
greetings... looking for potential part # and available retailers for a clutch dust cover boot on an NP 435 4 spd in a 74 Ford F600. thanks in advance. also interior door panels, headliner and the trim around the stock radio?
#953
If your looking for new parts you might try LMC truck catalog just type it into google they should have every thing your looking, also, if I'm not mistaking that is a standard cab with larger fenders and grill so all the interior trim pieces will be the same on all the f- series trucks and wrecking yards are full of them. good luck with your truck
#954
D5TZ-7277-A (replaced C7TZ-7277-A) .. Gear Shift Lever Boot / Obsolete
1967/72 F500/750 // 1973/80 F500/800.
BOSS MOTORS in Marysville KS has 1 = 800-453-3696.
#956
1967/72 F500/750 & B500/750 School Bus // 1973/79 F500/800 & B500/800 School Bus:
D1TZ-16054-A (replaced C7TZ-16054-B) .. Right Inner Fender Apron / Obsolete
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
D1TZ-16055-A (replaced C7TZ-16055-B) .. Left Inner Fender Apron / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
1967/72 F500/750 & B500/750 School Bus:
D1TZ-16138-A (replaced C7TZ-16138-C) .. Radiator Support / Obsolete
No Ford dealer or obsolete parts vendor has any.
#957
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 Air Brakes / 23,001-33,000 lbs. Gross Vehicle Weight Rating range.
K87 = F800 Diesel.
U = Caterpillar model 3208N or 3208T 10.4L (636 cid) V8 Diesel.
4 = Check digit, FoMoCo use only.
E = 1984.
V = Kentucky Truck Assembly Plant.
A52933 = 1984 Numerical Sequence of Assembly, the trucks specific serial number.
262397:
26 = New Orleans LA Ford District Sales Office, where the original selling dealer ordered the truck from.
2397 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
?41" Wheelbase.
K870 = F800 Diesel, 23,100 lbs. Gross Vehicle Weight Rating.
FH8: FH = Tan all Vinyl with Full Width Seat / 8 = Conventional Closed Cab.
SK = Spicer model CM5552A 5 Speed Manual Transmission.
JBN:
JB = Eaton model 22221 Two Speed Rear Axle / 6.17/8.41 / 22,000 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
K87 = F800 Diesel.
E = 1984.
262397:
?41" Wheelbase.
JBN:
#959
Hi NumberDummy , I was hoping that you could help me decode my vin and data plate info so I can do a brake job on my 1978 F600 dump truck . The Vin # is F61DVCA1690 The data plate reads 158 F616 AA8 3A E34 …….. 24000 2558177 I am trying to determine which brakes I have and wheel cylinders etc. and where I can get these parts to keep her going . BestRegards Ed
#960
VIN: F61DVCA1690 .. Warranty Plate: WB: 158 / COLOR: Blank / TYPE/GVW: F616 / BODY: AA8 / TRANS: 3A / AXLE: E34 / MAX GVW LBS: 24000 / DSO: 2558177
This info must be known to get the sizes of the brakes, but there are two different sizes of rear brakes.
Front brakes with 7,000 lbs. capacity axle are: 15" x 3.00" // Rear brakes with 17,500 lbs. capacity could be 15" x 5.00" or 15" x 6.00."
