OLD DECODES
#244
1958 F600 VIN Info, Please
VIN - F60D8R25313
WB - 154
Color - E
Date - 01
Trans - 4
Axle - 44
GVW - 17,000
Net Hp - 149 @3600
D.S.O. - 2549
Engine block and intake is a 'mustard' color. Valve covers and aircleaner are white. It is a Firetruck with 3200 miles on it.
WB - 154
Color - E
Date - 01
Trans - 4
Axle - 44
GVW - 17,000
Net Hp - 149 @3600
D.S.O. - 2549
#245
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
#246
C6TZ-6375-C . M/T Flywheel-164T / Marked: C7TE-A / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1966/68 Bronco 289 / 1969/79 F100 & Bronco 302 / 1975/79 F150 302.
Does your 1967 have a 10" or 11" clutch? The I-6 flywheel is specific to each.
#248
C5TZ-6375-N .. 240/300 I-6 M/T Flywheel - 164T - Use with 11" clutch / Marked: C7AE-C / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1965/66 F100/250 2WD // 1967/76 F100/350 3 or 4 speed / Ditto 1977 F100/350 before serial number Y20,001 // 1965/71 Galaxie/LTD 240 I-6.
I would think it's available from auto parts stores. There is 1 available NOS: MCDONALD OBSOLETE PARTS CO in Rockport IN = 812-359-4965.
#249
Info please > VIN # <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <woNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <wontVertAlignCellWithSp/> <wontBreakConstrainedForcedTables/> <wontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="--"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]-->2FTCR15Y3ECB22335
#250
#251
1963 F100 (wiper switch)
I have a wiper switch that does not work,,taken it apart several,,looks simple enough but still no electricity tru the switch,,,any exploded diagrams out there?,, or anyone have a good one for sale?,,thanks,,the ole fart Jimmy
#252
I am in need of a wiper switch for my 63 f100, jimmy
#253
If a single speed, does it have 4 terminals or 5 terminals?
btw: Please ask further questions in the 1961/66 F100 and etc. forum. This is the Large Truck forum for 500 and larger series trucks.
#254
wiper switch
mine has a total of 5 tabs,,power in and 4out
Are you 71 or older? If not, you're a 'young un' compared to me.
1963 F100: THREE different wiper switches. Is the wiper switch a single speed or a two speed?
