OLD DECODES
#63
You missed a set by a year:
https://www.ford-trucks.com/forums/1...8-pattern.html
Dodge motor homes had that pattern--5 on 8". They are 19.5 tubeless, which ends up with a little shorter tire than you probably have.
9R x 22.5s will work, but finding 5 on 8" 22.5 wheels is probably impossible.
5 on 8" split ring wheels with tube tires would be better than the Firestone wheels.
You mention "Budd" wheels. Budd is a wheel maker, and afaik, did not make the "widow maker" type wheel. HOWEVER, the widow maker Firestone wheels are the "Budd" type wheel, vs. the "Dayton" type wheel which is very different. Scroll down here for a brief explanation and pic:
what are budd wheels? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Do your rims have a split locking ring around the outside of the front wheel and the insides of the duals? Or is there a separation inside the wheel?
Ford two piece rims
Look at the video in post #4 here. My dad had a GMC 6x6 with these wheels, and he had the big ax-looking hammer to unseat the bead. What fun to change tires on that POS. (at least he bought a 1" impact for the lugs--finally)
Looking for the specific difference between "Split Rings" and "Split Rims/Widowmaker"
Ford two piece rims
#64
Thanks for the thread references. My wheels don't have a split ring around the outer, they are a two piece rim that separate in the middle. Do you know any more about which years the dodge motor homes had my bolt pattern? Just so I can narrow my search. I appreciate all the info being shared.
#65
RESOURCES
#68
Hi I posted in another thread for a VIN decode but then saw this here so thought I maybe should post it here... 74 Ford F700 Gas dump 5/2 running gear from the ad so here is the Vin>>> VIN# F70EVU48354... Just wanting to know how easy engine parts are to get... Thus the reason for the decode..
Thanks
RON
Thanks
RON
#69
HI NUmberDummy,
Can you tell me how the consecutive numbers are organized for the production runs and DSO options. MY Econoline has a VIN ending in "Q02422" Which looks to be the last of 1972's production it also has a special order DSO number of "1277" after the District code. (which I believe is the 1277th vehicle with Special Order Parts) Do those numbers refer to only the Econolines? the model within the Econolines? Or the whole production line in 1972? Any insight into how these codes were derived would be great. Can you look-up a model using the DSO code to find what it shipped with originally?
Thanks
Thanks
#70
Serial number (last 6 digits of VIN) apply to all series of 1948 and later trucks, 1961 and later Econolines, 1966 and later Bronco's.
6 digit DSO: First 2 decode to specific Ford District Sales Office that the dealer ordered the vehicle from.
Last 6 is the Domestic Special Order number. 1277 is related to your Econoline, but 1276 and 1278 could be any truck, Bronco, Econoline or a Passenger Car.
1972 serial number range: M40,001-Q00,000 / 1973 serial number range: Q00,001-S60,000.
Beginning 1970: Production date printed on the upper left corner of the Safety Standard Certification Label, glued to the B pillar below striker plate.
I have no way to get info for a Domestic Special Order, but you can get the info for a fee from martiauto.com
Late 1980's: FoMoCo was planning to THROW AWAY all the 1967/79 records. Kevin Marti, a Mustang/Shelby 'nut' in Phoenix AZ found out...and got ALL OF IT!
#72
But I did see a Ford Shop-Tips somewhere that said Q20,000 was the start of 1973 for the econolines (page 10 Vol 11 #2) but on Page #9 the BRONCO 1973 started with Q00000.
#73
Left/Right upper: 1972 / Left/Right lower: 1973.
