Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old 06-07-2018, 12:14 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by DBrawley
I sure have, Bill! Some of my buddies have Model A's and I go there with them from time to time. What a neat "time capsule" kind of place!
They have quite a few NOS parts, but very little place to display them, excepting the glass showcases. Most are boxed up in a backroom adjacent to the office.
Bill, the owner used to be partners with Harold Looney, who owned several Ford Parts Obsolete stores, the last one in Stanton.
Looney (who wasn't crazy!), purchased all the used and NOS parts (excepting Shelby/Mustang), when Valley Ford Obsolete in North Hollywood sold out.
  #872
Old 06-07-2018, 07:13 PM
04superduty6.0's Avatar
04superduty6.0
04superduty6.0 is offline
I'm looking at buying a 1979 Ford dump truck, all I have is VIN F82BVDC5899, door plate is missing. Present owner thinks carb needs adjusting or rebuilt, so I'm trying to figure out what engine and if possible what the GVW might have been.
  #873
Old 06-08-2018, 01:37 PM
NumberDummy
F82 = F800 (gas).
B = 300 1V I-6 or 370 4V V8.
V = Kentucky Truck Assembly Plant.
DC5899 = 1979.
Warranty Plate riveted to the left door face below the latch // Certification Label glued to the B pillar (door post) below the striker plate.
Both have the GVWR listed.
  #874
Old 06-13-2018, 09:52 AM
Oldmics's Avatar
Oldmics
Oldmics is offline
Hello
Could you help me out with the part# for a 1979 F700 fuel tank (gasoline) sending unit.
Its a round 75 gallon tank. If any other info is needed regarding the tank - please let me know.
And of course IF you can find one that is availiable.
Thanks so much.
John (Oldmics@Yahoo.com)
  #875
Old 06-14-2018, 04:09 PM
NumberDummy
And of course IF you can find one that is available.
Thanks so much.
There's a gazillion different sending units, because there's a gazillion different fuel tanks. Look on the top of the sending unit for its stamped ID number, post what it is.
Here's an example w/a 50, 75 or 100 gallon round tank: D4HF-9275-AA
  #876
Old 06-14-2018, 04:16 PM
Oldmics's Avatar
Oldmics
Oldmics is offline
Bill
Thanks for the reply
There does not appear to be any info on the top of the sending unit. Perhaps the unit has to be removed and the info is on the bottom side in the tank?
Would the information on the metal tag riveted onto the tank be of any assitance to you?
Thanks,John
  #877
Old 06-14-2018, 04:26 PM
NumberDummy
Bill
Would the information on the metal tag riveted onto the tank be of any assistance to you?
If there's no ID number, the sending unit was replaced from one bought in an auto parts store. It might be correct, might not.
If it's the ID number for the tank on that metal tag, that'll be a big help.
  #878
Old 06-14-2018, 04:32 PM
Oldmics's Avatar
Oldmics
Oldmics is offline
Tank is a D9HS 9002 TA 75 gal as I previously mentioned
Thanks,John
  #879
Old 06-14-2018, 04:48 PM
NumberDummy
Tank is a D9HS 9002 TA 75 gal as I previously mentioned. Where?
Thanks,John
I cannot find this ID number. There are several D9HS-9002's, but all have 3 letter suffixes.
Round, is it a step tank, does the truck have a gas or diesel engine?
  #880
Old 06-14-2018, 05:10 PM
NumberDummy
  #881
Old 06-20-2018, 06:04 PM
Spirit of '76's Avatar
Spirit of '76
Spirit of '76 is offline
Little help needed...
Hey Bill,
Wondering if you might have any info for me on this part;
https://www.ford-trucks.com/forums/1...l#post18045235
Thanks for all you do,
David
  #882
Old 06-22-2018, 04:23 PM
redneck_davis's Avatar
redneck_davis
redneck_davis is offline
Hey Mr. Bill . . just bought a f500 fire truck. F50bvm60968
L32 f500 4 8 A 42
L5000 126 3400 462152
  #883
Old 06-23-2018, 07:59 PM
NumberDummy
Originally Posted by redneck_davis
Hey Mr. Bill . . just bought a F500 fire truck.
F50BVM60968 // 132" Wheelbase / COLOR: Blank* / MODEL F500 / BODY: 4 8 / TRANS: A / AXLE: 42 / MAX GVW LBS: 15000 / CERT NET HP: 126 / RPM: 3400 / DSO: 462152
F50 = F500 (gas).
B = 300 1V I-6.
M60968 = 1972.
132" Wheelbase.
F500 (gas); 15,000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
42 = Rockwell model D100 Single Speed Rear Axle / 6.20-1 / 13,000 lbs. Rear Axle Capacity.
15,000 lbs. Gross Vehicle Weight Rating.
126 net HP @ 3,400 RPM
462152:
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
2152 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
  #884
Old 06-24-2018, 02:34 AM
aussie bl's Avatar
aussie bl
aussie bl is offline
wondering
hi mate been reading through your posts was wondering if you would have any info on my truck it in australia so maybe not thanks for any help these are the only numbers i have
cheers Stuart
  #885
Old 06-24-2018, 09:33 AM
NumberDummy
Sorry, cannot help with "Down Under" info, one needs an Aussie/New Zealand parts catalog which I don't have.
Quick Reply: OLD DECODES
