Code 311, low rpm bogging?
Old Jun 25, 2011 | 07:34 PM
broncoderek's Avatar
broncoderek
In my 95 F150 5.0 E4OD, I get a low rpm (like from a stop) bogging. Also when I get the engine in the upper rpms either by holding the shifter in a lower gear or if it's just about to upshift (and the rpms are on the high end) its got really good, smooth acceleration. If I'm just cruising at 1,100-1,300 rpms at say 40mph, I can feed in the gas pedal and nothing really happens until the pedal is depressed enough to downshift and then like I said earlier, it really goes (for a 5.0)
I've done a full tune up, Seafoamed it and did a KOER and KOEO test and all I got was a 311. The 311 was found with the KOEO test only.
I don't want to throw money at it but could the FPR be doing this with no codes besides the 311?
I had a vacuum leak but I fixed it today and it didn't help at all.
EDIT: Whenever I feel like a little hard-driving and I really "get on it" a few times, at the next stop, I hardly have any acceleration at all. Feels like a flooding carb until again, I eventually get in the higher rpms and it seems to clear out and the acceleration comes back.
Old Jun 25, 2011 | 11:03 PM
Josh88Ford's Avatar
Josh88Ford
whens the last time you replaced the fuel filter?
whats you fuel pressure at the rails?
Not a fan of seafoam. Try Neutra next time. Seafoam is twice as expensive but Neutra has more cleaning agents. Pint in the tank and pint in the crankcase.
Old Jun 26, 2011 | 06:50 PM
broncoderek
I guess a fuel filter will be the next attempt. Plus Ill get the FP and post it up if it's out of range.
Thanks for the reply!
Old Jun 26, 2011 | 10:18 PM
HrdDrv's Avatar
HrdDrv
Hows your timing look?
1Austin112
Sep 17, 2016 01:47 AM
20powerstroke02
Jul 25, 2016 07:23 PM
SJP
Mar 18, 2016 08:24 PM
Redneckfordf2502002
35
Jan 14, 2016 07:36 AM
imcqueen
21
Dec 31, 2015 10:55 AM
