4.9 EFI top end on an old 240?
Anyone ever tried this? I wouldn't mind EFI on my rig, and should probably just swap in a whole EFI 300, and I am equipped to do so. But I do suspect that my engine is a 240, and will try some rudimentary stroke-measuring through a spark plug hole one day soon.
But then I got to thinking that swapping the head and manifolding onto my 240, along with the wiring and fuel system, would be a kind of neat, and maybe a slightly easier, (no front clip removal) way to go.
Would any of the EEC IV controls work on a 240? I take it they're all MAP Speed Density based systems?
What about the OBD2 Mass Air system?
Heya meangreen,
From what I know, the 300 was speed density from 87 until 95. In 96, it was mass air, but those are pretty rare (but very cool if you can find one). I don't see any reason the EFI system wouldn't bolt right up to the 240. About the only thing I would think you would need to do is maybe smaller injectors? Dunno. But it would definitely be a cool setup.
RE the later EFI, it's not as easy as simply throwing in a smaller injector to address the missing 60 inches³ of displacement on a 240? Wouldn't the EEC need some recalibration for this? That would be enough to get me to just install the whole 4.9, which would be better anyway.
Hmmmm. I wonder if you could get one of the OEM 4.9 EECs to control three CFIs arranged in a 'three deuces' configuration? That would take some E-tuning for sure, but be about as cool as could be if it worked...
Heavymetal189
18
03-18-2019 05:18 AM
garypettengill
11-11-2006 10:02 AM
