e40d problem need help
Old Jun 25, 2011 | 11:24 AM
keith f250's Avatar
keith f250
new here so bear with me. while driving my 1990 f250 5.8 my truck would not shift out of second gear. stopped put truck back to park then reverse(it did engage) then back to drive started out fine but now it wouldnt shift out of 1st! so i manually put into 2nd and it shifte fine no clunk normal tryed to manually shift to drive and truck just reved like it was in neutral. manually put back in second and pulled over. I found that if i manually shift i have 1st and 2nd. if i stop or slow enough while in drive 1st will engage but will not up shift automatically only manually. Again when u manually try to shift into drive it just like neutral.there was no warning no slipping etc. any advice would be appriciated as this is my work truck
Old Jun 25, 2011 | 11:52 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » How To Run a Self-Test Here is a link on how to check for any trouble codes, always a good first step.
Old Jun 25, 2011 | 12:18 PM
keith f250's Avatar
keith f250
ill try it now but i always jumper wired sti to sig rtn lead
Old Jun 25, 2011 | 02:35 PM
Lazy K's Avatar
Lazy K
You meed to ground the sti and then turn the key switch to on. You should get 2 digit codes.
Old Jun 25, 2011 | 03:03 PM
keith f250's Avatar
keith f250
did it and got neutral saftey circuit failure and spout circuit open or spark angle word failure
Old Jun 25, 2011 | 03:22 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...-problems.html Click on this link and read the post by subford. I think that your next step should be to test the TRS as he describes (drivers side of trans). Check that the electrical connector is clean. If the TRS does not check out then I would replace it.
royalchoppers
Jan 23, 2016 02:47 PM
BCAUTOSOUND
22
Feb 5, 2012 10:54 AM
wats504
Feb 5, 2011 03:37 PM
70efftoofifty
Oct 8, 2009 06:55 PM
