another 95 P.S.D. wont start ?
Hey fellas and chicks if there are any, I'm a frequent flier on the 73-79 side "Bigdaddys76" so I'm not new to the site but am new to diesels.
Here goes my prob/story, I'm diesel dumb and will need you guys to dumb down your responses, initials don't tell me much, ie IDM IPR but am willing to learn and listen.
The truck in question is a 95 2wd auto 7.3 psd that has been sitting unstarted since early 2007. I bought two new 1125 c.c.a. batteries cleaned connections and turned key to wait to start and cranked only to get no fire off. Knew enough to see if the fuel pump was pumping by pushing in the shraider valve and am getting fuel there so I opened the fuel filter cap and witnessed fuel in the bowl as well. The glow plug relay is latching also. A local guy stated that since it sat so long the "pump" in front of the fuel assembly had leaked down the oil and to remove the 1/4 drive allen plug fill it with oil put plug in and it will sense pressure then fire over, No it did not. I read here about smoke out the tail pipe while cranking and it does not I did not watch the tach to see if it was moving while cranking either. What do those two mean? No fire to glow plugs and possibly a bad crank shaft sensor?
Help out a new guy if you will!!!!
When you added oil to the HPOP (High Pressure Oil Pump), 1/4 drive allen plug, was it low? Should be less than 1" from the top.
You should start with fresh fuel since it's been sitting so long. Try to dump as much as possible & refill with new. Add a can or 2 of anti algae additive <---Click. Replace the fuel filter too. Algae will plug your filter in short order. The filter will be black and slimy if you have it.
Even though you hear the Glow Plug Relay clicking doesn't mean it's getting through to the glow plugs. If the ambient temps are above 70F you don't need to be concerned with it though but it doesn't hurt to have them working. Jump the 2 large terminals on the GPR with a screwdriver ect and hold for 30-60 seconds. Jump in the truck and start it.
Hpop was empty it took exactly one quart to fill it up. The filter looked like new. Its definitly hot enough outside we had a heat index of 106 today and I still did the post to post trick but no luck. Fuel smelt good? like diesel should and had a good look to it. Anything else?
Check the HPOP again, you may need to fill it a couple times.
Unplug the ICP first (injection control pressure) sensor and try starting. If that sensor is bad and not reporting you have high pressure oil in the heads then the truck will never start. Disconnecting it will cause the PCM to assume a high oil pressure of 750 PSI and unlock the IDM (injector driver module) and try to fire the injectors.
You need high pressure oil in the heads to fire the injectors. If the ipr is sticking, sometimes unplugging the icp will unstick the ipr. The ipr is on the back side of the high pressure oil pump, which is in front of the valley under the resevoir you filled up.
One more question, was the truck sitting outside for the last 4 years? If so, and what I said doesn't work, pull off the idm and shake it to see if there is water in it. I'll get a pic of the idm for ya too
This is a picture of the backside of the hpop (high pressure oil pump) without a fuel bowl in the valley. The ipr (injector pressure regulator) is the brass looking deal about in the center of the pic with a black plug on top of it. You don't need to do anything with this quite yet, just unplug the icp and crank and see what happens
You are being a big help guys!
Yea the truck has been outside with all the climate temp swings but how would water get in with the hood closed unless your saying humidity changes have created condensation to build up in it? But I will check in the am.
Question, If it has the famous under recall original crank shaft position sensor would it just fail from sitting? And would that be something to start with? I'm thinking yes, but correct me if I'm wrong or would it at least give me some smoke out the tail pipe.
