replaced abs module twice same code b2477
Old 11-09-2016, 01:39 PM
gtuttle's Avatar
gtuttle
gtuttle is offline
at wits end. bought a truck with no PCM, got exact one off same wrecked truck (2008 f150 4x4). Neighbor has the Ford pass through tool & he programed the pcm & everything worked great except the abs light on. Code B2477 Module configuration. Took off abs module & went back to same junk yard to same truck & got the abs module off & put on my truck & the same code came back after cranking the truck. Neighbor can see the abs module & configured it to the new VIN, ran pump test & it worked, drove the truck & it sees all wheel speeds. Did emergency stop & the tires locked up & didnt pulsate. I have shop manual & performed pin test & everything checked out. found other test for CAN & they all checked out. The low tire pressure light is on too & that is all the lights on dash.
Suggestions please
Researched for days on the web & he checked on websites & nothing is there.
Old 11-09-2016, 03:41 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Need to do PMI on the PCM and ABS with the correct VIN. There is a mismatch somewhere, prob with the cluster
Old 11-09-2016, 04:39 PM
gtuttle's Avatar
gtuttle
gtuttle is offline
he did that 6 times & each time it seemed to take, then restarted & each time came back with same code
Old 11-10-2016, 11:18 AM
70f100longbed
Im not familiar with a Ford pass through tool, is it the same as IDS?
Old 11-10-2016, 11:31 AM
gtuttle's Avatar
gtuttle
gtuttle is offline
He said, yes that is what it is.
Old 11-11-2016, 11:58 AM
70f100longbed
Not sure on this one. Maybe try programming both modules with as-built data?
Old 11-11-2016, 04:51 PM
gtuttle's Avatar
gtuttle
gtuttle is offline
he did, I went back to junkyard & got a different one & will put it on & he will get the tool from work on Monday & hopefully will take configuration
Will let the post know what will happen
thank you
wiredgeorge
1999 to 2016 Super Duty
05-19-2019 06:47 PM
aortizexcursion
1997-2006 Expedition & Navigator
01-06-2018 03:24 AM
85F350IDI
03-03-2016 04:27 PM
like2ride
2004 - 2008 F150
04-20-2012 11:08 AM
pick1967
01-13-2011 07:38 PM
Quick Reply: replaced abs module twice same code b2477
