How much oil?
06-21-2011, 10:47 PM
How much oil?
Was wonderin how much oil my 1992 F150 holds. It has the 302. Any help is appreciated.
06-21-2011, 10:59 PM
on
I assume you mean engine oil, if so 6 quarts including the filter. The 302, 351, and the 460 all take six quarts, not sure what the 300 takes.
06-21-2011, 11:02 PM
The capacities chart in my Chilton manual (covers 87-96) says a 92 F-150 with a 5.0 takes 6 qts of oil. Same as my 91 5.0.
Chris
Same chart says 6 qts for the 4.9 also.
06-22-2011, 01:03 AM
on
My 1996 F150's manual said 5.0 qts for all engines, but said 6 with filter change.
I missed the last part, put 5 in with a filter change and the oil level reads full on the dipstick :shrug:
06-22-2011, 04:05 AM
I agree slow...My dads 302 uses 5 qts, INCLUDING filling the filter up....My 300 uses 6....Filling the filter up.....
06-22-2011, 08:32 AM
on
5qts. for my 302. The only engine I've seen use 6qts(or more since it's hungry) is my dads '01 Suburban with a 5.3l. I say it's hungry because it doesn't leak oil and there's no blue smoke or the burning oil smell coming out of the exhaust.
jeff gammon
07-30-2012 06:19 PM
billb2000
Flathead V8 & Flathead 6
05-07-2012 06:26 PM
Crewcab Turbo
18
09-17-2011 02:25 AM
Pwarrenn
6.4L Power Stroke Diesel
30
10-11-2007 09:41 PM
MJW
03-15-2004 03:05 PM
