1948 panel
Old 09-19-2011, 05:58 AM
elliot's Avatar
elliot
elliot is offline
1948 panel
we just removed a stuck flathead 6 that is stuck with a 3speed with power take off is there any resale value of any of these parts the engine looks untouched and complete thanks elliot
Old 09-19-2011, 09:35 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
A stuck flat six doesn't have much value unless it can be unstuck relatively easy. They are expensive to rebuild. The most valuable part is the exhuast manifold as long as it's in good shape with the mounting flange and bolts still in tact. These manifolds tend to crack in this area.
There might be some value in the tranny but it sounds like with the PTO it's the heavy 3 speed which I don't think is as valuable as the light duty 3 speed. If it is the heavy duty 3 speed I think it should have the hoghead, the casting between the transmission and the flywheel bellhousing. This part is used by hot rodders to install a modern transmission behind a flatty.
Old 09-19-2011, 09:44 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Why would a Panel have a PTO?
Old 09-19-2011, 09:57 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Ilya,
Most of the panels I have found in my area, not many, but a few were owned by farmers who used them to haul eggs to market. Maybe they were also used to run pumps or other farm implement. I don't know for sure but that's my guess and I'm sticking to it. Farmer can be very inventive with the use of their equipment, remember, I live among them.
Old 09-19-2011, 11:29 AM
38 coupe's Avatar
38 coupe
38 coupe is offline
The light duty three speed never had a removable hogshead. The heavy three and four speeds did. The heavy three should have T87D cast on it and the four should have either T8 or T9 cast on it.
dannko
2017+ Super Duty
15
02-20-2017 12:46 PM
jimdandyf100
07-17-2014 06:48 AM
tylert1976
12-05-2012 11:50 PM
Virto
01-30-2009 06:53 PM
2many56s
01-02-2009 06:49 PM
Quick Reply: 1948 panel
