AC intermittent
AC intermittent
2004 6.0 176,000 miles
A/C started blowing hot sometimes...mostly when sitting at a light, but sometimes while running down the freeway. The condensor is clean, and the fan works.
It will blow hot for a while, and then start blowing cold.
When checked with guages, the pressures where in line.
I was told it could be a blockage, or a bad pressure switch.
Where are the two pressure switches located?
Has anyone had the same problem, and what was the fix?
mgmoore7
09-12-2006 07:01 AM
