I thought long and hard when you suggested that I do this mod to my truck George, because it does sit high in the rear!. And I have made a decision about leveling my truck................ Yep, I'm going to load it with cinder-blocks!
Looks good george!!! very spiffy!! now the fix for the loose nut behind the wheel is torque the nut to 96 ft lbs then back it off 90 degrees then retorque it to 67 foot pounds then ur good!!!
That's a good one Ronnie but I don't believe that will fix George
