'53 f600 side window removal
Out through the access panel on bottom. The glass will be mounted in the metal channel and should just have 2 clips that hold the glass channel to the window regulator assembly. At least for the 48-52's.
My 53 C600 is missing the door glass until I find decent used or break down and buy new glass.
Later
Josh
Later
Josh
Actually, no, you need to remove the division bar in order to remove the glass. In order to remove the door glass;
1) remove the inside inspection cover
2) roll the window down, and access the rollers/clips, as mentioned in the previous post
3) open the vent window
4) remove the screw, bolt, or nut that holds the lower bracket of the division bar
5) remove the screw(s) at the top of the division, under the weather strip
6) dislodge the glass from the tracks at the division bar, and rear channel
7) remove through the inside panel, or out through the top. It won't come out, without loosening, or removing the division bar.
joes1992f250
01-28-2017 02:38 PM
