hi everybody. new truck new to the forum need info
so i just bought a 81 f150 4x4 it has 96xxx miles on it and looks like it was a work truck as it's a bit rough but got it from a shop and it has had a lot new parts (master cylinder, fuel pump , starter plugs wires, distributor, radiator etc...)put on and seems to be in good mechanical shape. it does however have a hole in the floorboard but i'm planing on getting a jcwhitney patch for that. the biggest issue is the 4wheel drive works but it leaks a lot from the back of the transfer case seal where the main drive shaft goes in. and in general there is a lot of seepage from all over the motor and trans.... so i'm wondering if any one know where to get the seals I need because i have had no luck on google identifying the tranny and transfer case. i searched on here and found a lot of conflicting info. here is a pic of the door badge and the underside of the trans and transfer case. any help would be appreciated. thanks.
on
I can help you decode your certification sticker.
VIN NUMBER: 1FTDF14E0BPA90305
1FT: = Ford Motor Company USA: Complete Vehicle
D: = Hydrallic Brake System GVWR Class: 5,001-6,000 pounds
F14: = F-150 4x4 Regular Cab Pickup
E: = Engine: 4.9L (300 CID) Six Cylinder engine.
0: = Check Digit
B: = Year Model: 1981
P: = Plant Of Manufacture: Twin Cities
A90305: = Production Sequence Number
WB: = Wheel Base: 133 inches
GVW: = F141: F-150 4x4: 5700 LBS
BODY: MD4
M: = Special Seat
D: = Interior Color: Medium Red
4: = Regular Cab Styleside Pickup Bed
EXTERIOR PAINT COLORS: 1P / 1C
1P: Medium Gray Metallic
1C: Black
AXLE: 16: = Rear Axle: 3750 LBS: Ratio 3.50: Non-limited slip
TRANS: B: = Clark (Tremec) 4 speed Overdrive transmission
DSO: District Sales Office: or District Special Order:
76: = Denver District: District Special Order: F0159 / T0694
0: = Check Digit
BODY: MD4
M: = Special Seat
1C: Black
...the biggest issue is the 4wheel drive works but it leaks a lot from the back of the transfer case seal where the main drive shaft goes in. and in general there is a lot of seepage from all over the motor and trans.... so i'm wondering if any one know where to get the seals I need because i have had no luck on google identifying the tranny and transfer case. i searched on here and found a lot of conflicting info. here is a pic of the door badge and the underside of the trans and transfer case. any help would be appreciated. thanks.
That looks like it's an NP208, here is from the 1981 factory shop manual:
As for the seals, well, I suggest you first wash it with a hot-water pressure wash, then watch it and see exactly what's leaking.
NAPA auto parts can sell you some dye you can put into the transfer case, it glows under black light, this can help you identify the source of the leak(s).
I have the BW1345 variant, and it leaks at the input shaft even after having replaced the seal.
Turns out the front bearing is shot, the input shaft wiggles around way more than it should. I'll rebuild the entire thing "one of these days."
Yours may be in similar condition.
When you get it cleaned up and figured out, look at www.drivetrain.com for rebuild kits & seals & whatnot.
luthoro
20
11-09-2012 08:58 PM
