Fuel systems and California
Old 06-17-2011, 03:32 PM
sportsdad's Avatar
sportsdad
sportsdad is offline
I'm wondering if anyone has gone through smog with fuel system mods. If so, what are your mods and how did you do?
Old 06-17-2011, 07:02 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
I do not have any fuel mods, but I do know that the smarter shops DO look for them. They are not OK unless there's a CARB number for them.
Sorry for not answering from the pool you wanted to hear from.....
Pop
Old 06-17-2011, 08:10 PM
sportsdad's Avatar
sportsdad
Pop
Thanks Pop, that's what I'm thinking also.
And don't worry, your comments and insight are always welcome.
Old 06-17-2011, 11:45 PM
SpringerPop
Ya' know, I'd bet that if the fuel mods were done all with factory-looking, formed steel tubing, it would be really rough to discern. "AN" fittings are out. Nothing fancy might just play.
Pop
Old 06-18-2011, 02:32 AM
73ferdf250highboy's Avatar
73ferdf250highboy
73ferdf250highboy is offline
my old shop i worked at has started smogging diesels: he said:" no smoke- no check engine light- nothing to obvious-pass."
when i was in smog school 2yrs. ago they were just starting to formulate a plan of action for diesel smogs, in ca. what a load of bs that whole program is. find a good shop that knows diesels. shouldn't be that difficult.
where you located? in norcal- sac area?...i got some buddies...
Old 06-18-2011, 05:05 AM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
In Arizona they ask us to turn our programers to stock
Old 06-18-2011, 08:16 AM
sportsdad's Avatar
sportsdad
Pop
I've thought the same thing. Only problem is that i don't want something too complicated if I have to reverse it to pass.
Old 06-18-2011, 08:17 AM
sportsdad's Avatar
sportsdad
I'm in Bakersfield. There are some good guys here and some not so good guys here. Know a good one?
Old 06-18-2011, 09:13 AM
73ferdf250highboy
sorry, not in bakersfield. is that kern county? i stay outta that area- got a speeding ticket there years ago heading to vegas. had to drive 8hrs back from sacramento(miss a $200 day of work) to sit in a court room to for a $400 dollar ticket-for doing like 90 in my wifes autobahn burner...anyways
again sorry i cant help down there.
Old 06-18-2011, 10:52 AM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
My Ford is smog exempt with 15,000 VW, but went for smog with Mercedes diesel. From long list of items only 2 applied to my model:
-vacuum connections.
-O2 sensor connections
They didn't even plug-in scanner.
What a waste of money.
Old 07-04-2011, 02:24 AM
stugots's Avatar
stugots
stugots is offline
What about having stage 1 injectors and running a Dp tuner set at stock modified?
Old 07-04-2011, 12:38 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Hide your DP switch (hopefully you don't have the gauge mounted switch) and you'll be fine.
Stewart
Old 07-04-2011, 12:46 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Damn, i got the FRx and hutch mod, goin on with mine. But, since my truck was purchased from a family that owns a smog shop, jopefully its a simple look, no smoke, hear ya go..if not, i'm up the creek w/out a paddle.
Old 07-04-2011, 01:37 PM
stugots's Avatar
stugots
stugots is offline
Stewart
It is not mounted yet.
I failed smog once due to a glow plug code. So ,while I did the glow plug replacement I checked my injectors and found 2 that were not pumping oil.
Now that I found Riffraff and 2500 later here is what is coming.
Stage one injectors.
F5 Tuner
Gauge led switcher
HPX
FRX
6637 Filter
AIH delete Plug
Quick drain valve
650 custom dash kit with 6 switches
And the AE ford program.
So Im thinking to put in the injectors and hide the gauge
, pass smog and then install all the goodies.
Old 07-04-2011, 01:54 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Got mine smogged here in CA and thats how mine was treated.
He let it idle. No CEL.
He gave it some pedal. No smoke.
He checked for obvious modifications. None.
Pass. Took about 20 mins.
