lug nuts and studs...parts available for 61 F600?
Bill (ND) or others:
In trying to get the front tire/rim off of my 1961 F600, I broke off one of the studs!! The others are hard as hell to break loose.
Are these studs readily available from napa, etc.??
Also need the spring that holds the 2 drum brakes together. Part number?
Thanks
Thanks
I hope you know that you've got both left hand and right hand threads. Napa probably can get replacement studs, but to me I'd want to take the kid behind the counter a part number so all they have to do is place the order. The Dorman on-line catalog lets you look at the studs live size and match your busted one. Yours is 3/4" x 16 tpi, so you'll just need to match the spline diameter, length, etc. Here's the Dorman link. Stu
https://www.dormanproducts.com/catal...ec10_Part5.pdf
Thank you
Yes, back same as the front. If you take a close look at the stud you twisted off, you'll no doubt find a letter "L" molded into the end of the stud as well as an "L" on either the face or one of the flats of the nut. The Dorman catalog has both left and right hand threaded studs/nuts. Stu
When you get the replacement installed and are ready to remount the wheel, you'll also want to study up on torque settings, and whether to lube or not to lube the stud. These subjects generate heated debate both here and on other web sites. Me, I follow the manufacturer's recommendations which is a dry stud torqued to 450-500 lbs. Others claim that oiling or use of anti-seize works for them. Below are some old threads that will give you the arguments. Stu
https://www.ford-trucks.com/forums/7...-lug-nuts.html
Mechanical engineering other topics - Use of Anti Seize on vehicle lug nuts
Use of Anti Seize on Vehicle Lug Nuts
Thoughts on using anti-seize on lug studs - THE H.A.M.B.
Debunking a myth
Debunking a myth
Debunking a myth
Debunking a myth
What part numbers for the brake parts (springs, shoes, etc.) lugs and nuts. Thank you!
Bus Girl
04-12-2017 10:55 AM
f100today
03-31-2017 07:09 AM
CJ2003F250SD
1999 to 2016 Super Duty
10-15-2014 02:01 PM
