Front wheel bearing going bad (4x4 X)
I just ordered the premium hub assemblys from Napa. Part Number BRG BR930420, List price is $384, if you know somebody at the store you may be able to get them for $260.00+/-. Searched on here and a few other places and the reviews for the knock off were not favorable. I hope they are worth it.
I just replaced the wheel hub bearing assemblies on my Ex two weeks ago. I looked up various auto parts stores and found Autozone carries Timken brand bearings (one of the best). They were also fairly cheap at $260? I think. Rock Auto had them cheaper but I needed to replace the bearings ASAP.
So I asked my buddy who has a shop if he could order the part for me... and he said the parts place said there is a coarse thread and fine thread option. WTH!! Anybody know if there is a way to tell the difference without taking it all apart? And is it talking about the lug studs or the studs holding the bearing assembly to the spindle?
I did the passenger side ball joints while I was changing the bearing. They looked like they might be original at 103k. The upper ball joint was completely destroyed.
<P>Wheel bearing off.<P>
<P>
<P>Axle shaft out. I wonder why it is necked down like that?... so we know where it will break!<P>
<p>
<P>Axle shaft out part 2. Race for the needle bearing on the back side of the wheel bearing is in good shape.<P>
<P>
<P>Spindle off.<P>
<P>
<P>Old ball joints removed from spindle.<P>
<P>
<P>NEW UPPER/OLD UPPER/OLD LOWER/NEW LOWER<P>
<P>
<P>New ball joints installed in spindle.<P>
<P>
<P>
So.... I thought my steering box needed to be tightened because of the play in the steering wheel (about one inch either direction before vehicle would start to turn) but it was all that slop in the ball joint. Steering feel is fantastic now.
<P>
<p>
<P>
<P>Spindle off.<P>
<P>
<P>
<P>
<P>
<P>
