1987 starting problems
Old Mar 26, 2003 | 06:48 PM
mcne's Avatar
mcne
My 1987 F-150 doesn't always start when the key is turned. It does nothing, not even crank over. I used to put it in nuetral then turn the key and it would start no problem. After that it would start when in park no problem. What component dictates when the starter can recieve power in my steering column? I know there is a nuetral safety switch but where is that located? I am 98% sure the problem is some switch or contact that is worn and not allowing power to flow. I have had my column apart many times and have replaced the entire unit with another unit over a year ago. Any suggestions?????????? Brian.
Windstorm
Sep 17, 2014 10:22 AM
Fern89
Dec 28, 2012 09:15 PM
wagonerkl
Jan 14, 2010 11:38 PM
GT V10
Nov 6, 2009 01:09 PM
raerjim
Jan 22, 2009 07:23 AM
