How much regular gas can you add?
on
I would not do any gasoline.. there is no lubricating properties in gasoline.. here is some more reading:
Mixing Gasoline And Diesel
Add some stanadyne for better mileage..
I've added Lucas injector cleaner to my gassers for years now, but I've yet to do it to my diesel. I'm afraid of any adverse consequences or what could break loose in the injector area and create an even bigger problem. I know the previous owner of my truck did not use any additive or injector cleaners.
[quote=clintbonnie;10481173]I don't understand.. you say you adding 10% ATF to each fill up of diesel ? That would be about 3 gals of ATF at $16/gal, or $48 ? Why ?[/quote
They are probably using recycled atf. From the previous posts looks like the were talking up to 90% atf to 10% diesel. Seems kind of high to me but I don't know much about it.
I just started doing this, but I am only running 80% Diesel and 20% to see if I notice anything. I have a friend with a Cummins who works at a dealer ship. They take two 55 Gallon drums, one with used ATF, and one empty. They hook an electric pump to a car battery that pushes through a filter into the other drum. then you empty that into buckets and funnel them into the tank.
So far, it seems to idle a little smoother, and smokes more. I haven't run it long enough to know mileage difference, other than say I put in 37 gallons at $140 or so, burn 10 off and put 10 more gallons of ATF in, my mileage per dollar increased significantly as thats $40 saved for another 180 miles
Its scary, but seems to be fine.
Automatic Transmission Fluid Fuel - Alternative Diesel Fuel - Diesel Power Magazine
TreySpooner65, is that article about you?
