oil cooler rebuild - another ?
So I want to teardown the oil filter head and soak it, blow it out, etc. to get all the final crud out of it...the crud that got into it from cleaning the exterior + coolant residue.
Anyhow I got the circle clip out of the block side fitting (not the bypass with the wafer), but the interior items won't come out. My guess is that the aluminum has mushroomed out a little making the piece hang up before getting out.
So, should I open the aluminum up very little....or am I missing something.
I've tried all sorts or realigns but it wont come out.
Let me know
Better Question - What the heck is that little thing in there and what is it supposed to do, the steel cylinder with the four small divets, does it rotate on it's own?
Let me know
i removed the 3 bolts at oil filter neck, then the 2 bolts on front of cooler...one is very hidden under the pullies. the entire assembly came right out...i flushed it with water, then air. some materials/crud didnt come out with water or air, so we used a coat hanger very straight and ran it thru each chamber. it was a very messy job and when you try to get the gaskets in and the bolts...thats tough. good luck
