Do you guys think I could trust my truck on a long trip??
I want to take my 85 6.9 pickup on a trip that is about 800 miles in all. My motorcycle would be in the back and my wife and 2 young children would be with me.
Normally we would take our mini van on this trip but I want to take my motorcycle. My wife seems to think we will be stranded if I attempt this, and she may be right. So before you answer, let me tell you about my truck.
I have had it for almost a year. When I bought it, it was basically a completely un-maintained pile of junk, but it did run.
Since I have had it, I have done the following:
rear axle drained and refilled with coastal 80w90
rear axle seals replaced
rear axle aligned so truck tracks straight
rear brakes completely gone through, replaced everything except drums
replaced some brake line
replaced both rear E-Brake cables
rear shocks replaced
new fuel pick ups and sending units
replaced bed
drive shaft center support bearing replaced
all new u joints on rear drive shaft
trailer hitch installed
transfer case drained, seals replaced, filled with ATF
motorcraft glow plugs installed with push button relay setup
replaced some leaky return line T's and hose
replaced starter solenoid
cleaned battery cables, placed in loom, used large clamp style connectors
air filter
oil change and filter
fuel filter
replaced the bailing wire with a junkyard antenna
tinted glass
repaired A/C (compressor clutch, belt, 134a conversion,cools to 39 degrees now)
turbo blower fan mod
new cd stereo head unit
new pioneer speakers
repaired power windows
repaired power locks
new Ford emblem installed on grill
front axle topped off with 70w90
replaced at least one belt
flushed cooling system, filled with correct coolant and SCAs
replaced lower rad hose
replaced steering gear box
replaced power steering pump
new heater core
numerous interior repairs, glove box latch, remounted fusebox, etc
replaced and repaired probably 10 or more other things that I can't even remember right now
2 new BFG KM2 Mud Terrains in the back
transmission fluid looks good and it shifts as it should
So it has come a long way
Here are the things that are potential issues...
one of the glow plug holes has messed up threads, I ended up just driving a glowplug as far into it as I could but I couldn't thread it all the way down. It seems to leak a little bit apparently though bc it blows some tiny bubbles in fuel that had puddled around it.
the dang transfer case still leaks through the splines
the power steering leaks still even though I have replaced a lot of it
the engine has blow by and low idle oil pressure
some hoses are in questionable condition (heater hoses and transmission cooler lines mainly)
the front wheel ujoints are trashed
the front end sits on the bump stops from bad shackle bushings or maybe just worn springs
Unknown mileage
So if you read this far, then I want to thank you for being so patient. Now, tell me if you think it is trustworthy for 800 miles in triple digit heat, with wife and little ones???
Luke
replaced bed
air filter
fuel filter
tinted glass
new heater core
Unknown mileage
Luke
Wow....ummm... you defenently replaced alot of stuff on that thing!
I've always went on longer trips with older vehicles, mostly had good luck, but did happen at times where I had to stop and redneck fix something the best I could to make it somewhere where I can properly fix it.
But i'm always well prepared in any old truck I drive. Anything that breaks etc. most of the time, I can fix something up and get going again. (no way in hell i'm paying a tow truck)!
Stuff to carry on long trips:
- Belts
- Hoses
- Extra starter (if your truck is an automatic witch it is)
- Couple fuel filters
- Chains
- Booster cables
- Powersteering fluid (since yours leaks)
- Couple quarts of engine oil
- Duct tape and brush wire
- And some basic tools
Now for your low oil pressure. Do you have a real gauge or are you depending on the dash gauge? If you don't have a real gauge, install one! The dash gauges are borderline useless!
I wouldn't worry about the transfer case leak, as long as it's a slow leak. Make sure it's well topped up before you go and you should be fine.
Really the only thing I see worrying is the U-joints (witch ones exactly? the ones in the axle or on the driveshaft?)
And your questionable hoses/lines, witch if I were you, I'd replace right now, takes a couple minutes to do so....
- Belts
- Hoses
- Chains
- Booster cables
If you have to ask people you don't know if your truck might be dependable enough for a trip, THAT alone should answer your question.
You don't trust that your truck wouldn't break down.
Going your self is one thing. Taking the biscuit burner and rug rats along is something else again. You would also never hear the end of it if you got to spend vacation and extra money sitting in a motel room waiting to get the truck fixed.
Take the easy way out on this one!
- Belts
- Hoses
- Chains
- Booster cables
- Belts
- Hoses
- Chains
- Booster cables
I have a regular stock gauge, at hot idle it shows little or no pressure, on the highway it reads halfway.
the bad u joints are the front ones on the wheels, so as long as I don't need 4x4, I should be ok. The aren't broken, but they have a LOT of slop in them.
installed spare tire carrier
replaced passenger side sun visor
replaced broken ac vents
replaced throttle cable
replaced some more leaky fuel return lines
"installed" some Lucas power steering stop leak
How does this rubber washer thing work? I am confused.
