FE mystery ???? WHAT IS IT
07-14-2011, 11:50 AM
on
I HAVE A FE BLOCK THAT DOES NOT HAVE 352 CASTED IN FRONT OF IT ON THE PESSANGER SIDE OF THE BLOCK JUST BELOW THE HEAD THERE IS A CASTING NUMBER THE READS C6MEA IM PUZZELD TRYED TO FIND INFO AND NO LUCK ANY ONE NOW ANY THING ABOUT THIS
07-14-2011, 02:07 PM
What is the bore size?
2 bolt mains, right?
Is there a crank in it?
Garden variety 390 or 410 block, seeing as how C6ME is 1966 Mercury.
07-14-2011, 02:39 PM
on
I FOUND THE LINK TO MUSTANG TEK GOOD INFO THANK YOU VARY MUCH
07-14-2011, 07:36 PM
352 is cast in the back of the block behind the bell housing IINM.
07-14-2011, 08:22 PM
on
"352" is also cast into the lifter valley on some of them. C6ME-A casting can be anything from a 352 to a 428. Heck, could even be a 330 FT. Only way to know for sure is to measure the bore and stroke. If it's a bare block then it's whatever you want it to be.
07-15-2011, 01:12 AM
Using all CAPS is the same as YELLING on the forums!
chris17453
Large Truck
04-17-2015 10:24 PM
RandallWhipple
02-07-2015 04:58 AM
cies_69_ford
01-15-2012 09:44 PM
gliderdad
03-27-2009 11:40 PM
