FUEL PUMP RELAY
THE INERTIA AND FUEL SELECTOR SWITCH HAVE NO FIRE. THE EEC #6 HAS A VERY WEAK SIGNAL JUST LIKE THE HARNESS PLUG THAT GOES INTO THE FUEL TANK. IVE CHECKED THE RELAYS AND FUSES. DOES THIS MEAN IF THERE IS NO FIRE TO THOSE 2 SWITCHES ITS PROB ONE OF THEM THEN?CUZ I HAD A FORD ESCAPE HIT MY TRUCK FROM THE BACK IN FEB 2011 SO DAMN IM WORRIED. THAT INERTIA IS LIKE 80 BUCKS.WHAT U RECOMMEND OR THINK?
question for subford
Hey subford, I am having a fuel issue in a 89 F250. I drove the thing home from work, parked it, and in the morning it ran for about 5 seconds and shutdown. I have changed the fuel pump relay. I can hear the pump in the tank buzzing but I have no power at the high presure pump on the frame rail. Where is the inertia switch located and do you think that is where I should be looking? Thanks in advance
Sounds like you have a problem between the Inertia switch and the high pressure pump on the frame rail. But make sure you have power at the selected in-tank pump.
Use a test light with a bulb in it to test for power as you need to load this circuit for testing and a meter just will not do.
Thanks for the schematic and advice
I'm heading out to get going on this again. I made some progress yesterday by locating the relay and changing it. I still have no clue as to where the inertia switch is located though. If I knew where it is I could trace the wire to the HP pump on the frame rail...Thanks again for the schematic...It's more detailed than the one I had.......
FordAnne
08-15-2023 08:21 AM
