how much power is left on the table
I just got Beans stage 1s and their chip. Im the hot position my ICP drops to 1900=2000psi and the check engine comes on, so IPR Duty cycle has to be about 50%. This was in four gear @3k rpms, 28psi boost, 1400* pyro.
What amount of power is left if I get a bigger HPOP?
Is the T500 big enough?
If you have 50 at idle with a new pump then I'd say you fine shimming won't hurt just don't go over75psi. If you gEt a new HPOP you will fill get all the performance out of the injectors but the to be able to use all of you new found a intercooler will be a big plus to to keep your EGT's away from that 1400*
Foxtrot35Oscar
07-16-2010 09:52 AM
royt911
04-29-2010 07:23 PM
PowerstrokeJunkie
43
04-30-2008 04:50 AM
