Torque converter lockup switch.
Old Jun 8, 2011 | 07:05 AM
strokin83's Avatar
strokin83
Hey guys I was curious if anyone has found a way to wire in a TC lockup switch. I work out here in the mountains of WV and climbing these wormy steep access roads gets the tranny temps pretty high. I know it's possible on the 7.3 my buddy has his wired up and loves it. I'm thinking if I can lock it up I won't have to stop and high idle until it cools down. I know pulling 6k behind me up these roads is def a workout for the truck. Last year in 35,000 miles I went through 3 sets of tires, twisted my front drive shaft, and broke the yoke on my right side front axle shaft. So that should give you an idea of how crazy it is out here because these trucks are tough.
Old Jun 8, 2011 | 07:27 AM
npccpartsman's Avatar
npccpartsman
I don't think it's possible on a 5R110 unless it's done in the programming. What kind of trans. temps are you talking about? These can get pretty hot with no damage. Also, what kind of maintenance schedule do you follow?
Old Jun 8, 2011 | 09:21 AM
william_04_x's Avatar
william_04_x
It's been done before, and the TC didn't last long afterwards.
Old Jun 8, 2011 | 10:33 AM
Kert0307's Avatar
Kert0307
How about adding an electric fan with a thermostat to turn it on onto your trans cooler. Then you will get full cooling no matter how fast you are going or what the engine rpms are at?
Old Jun 8, 2011 | 10:50 AM
npccpartsman
There should be no need for an electric fan with the size of the stock fan and transmission cooler. I'm wondering if the fan is operating correctly at all. Is your EGR valve plugged in?
Old Jun 8, 2011 | 10:54 AM
strokin83's Avatar
strokin83
Yea I've been seeing 250 pretty regularly. And that's even when I'm climbing in 4 low. I'm thinking it wouldn't hurt for some kind of aux cooler with a fan that I could kick on every time I pulled off the road. As far as maint. I drain the 8qts out of the pan every other oil change sometimes I do it every oil change when I'm working it this hard. It comes out bright red every time.
Old Jun 8, 2011 | 10:58 AM
strokin83's Avatar
strokin83
As far as the fan it's working properly I replaced it 3 months ago. On the EGR I deleted the cooler but he valve is still in the intake and plugged in.
Old Jun 8, 2011 | 11:00 AM
Kert0307's Avatar
Kert0307
The stock fan is controlled by the coolant temp and CFM is related to engine rpm. If you are traveling slower speeds and lower engine rpms, there probably isn't enough air flow over the trans cooler, which is why he has to stop and put the truck into high idle to get it to cool off...
Old Jun 8, 2011 | 04:29 PM
XB70's Avatar
XB70
The Stationary Elevated Idle Control circuit locks up the torque converter through programming. Maybe there is a way to activate the lock up while under way.
mototrig
Aug 5, 2017 09:05 PM
hdfe
Feb 27, 2017 10:32 AM
asavage
Aerostar
15
Jul 11, 2016 09:24 PM
elskeptico
Apr 21, 2012 03:14 PM
dylan8427
Dec 16, 2010 05:47 PM
